Author Topic: T-molding and rubber mallet  (Read 1355 times)
bravesfan
  • Last login:August 30, 2015, 06:04:00 pm
« on: September 02, 2005, 10:27:35 am »
I used a rubber mallet to install my t-molding.  However, the rubber mallet seemed to put some small dents in the molding.  Is there any way around this?
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:August 16, 2020, 02:42:43 pm
  • I am t3h GAY!!!
Re: T-molding and rubber mallet
« Reply #1 on: September 02, 2005, 10:57:08 am »
Don't pound so hard?
After all... The whole point of using a rubber mallet to install the t-molding, is so that doesn't happen.
« Reply #2 on: September 02, 2005, 11:11:26 am »
I found it quite hard to install evenly tho to be honest.  It's easy to push the molding in *too* far.
ahofle
    • Arcade Ambience Project
« Reply #3 on: September 02, 2005, 04:41:11 pm »
Use a soft towel folded a few times where you hit.  This worked really well for me and avoided the scuffs and imprints.
Stingray
« Reply #4 on: September 02, 2005, 04:51:38 pm »
I always just push t-molding in by hand. I've never seen the need to use any tools for that particular job.
-S
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« Reply #5 on: September 02, 2005, 04:56:02 pm »
I'll second Minwah on that one though...I've used a towel and hit the stuff lightly and still have places where it looks "uneven."   For now I've decided it just gives my cabinet "character"  :D
NoOne=NBA=
« Reply #6 on: September 02, 2005, 05:13:05 pm »
I used the towel method with a regular hammer, and mine looks great.
The two things to be careful of are banging too hard, and getting the molding in too deep.
I used VERY soft taps, and just kept tapping until it seated to the correct depth.
That way I didn't ding the molding in a particular spot by hitting too hard, and it didn't go too deep because it took more than one hit to get it where it needed to be.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #7 on: September 02, 2005, 08:49:36 pm »
I haven't installed any t-molding yet, but I don't understand how it can go in too far? isn't the underside next to the spine flat?  I would think that you would just push it in until it's flush, and it shouldn't go in any further.  Is that not true?
« Last Edit: September 03, 2005, 04:30:54 pm by AceTKK »
I want my own arcade controls!
  • Last login:May 06, 2024, 04:31:28 pm
« Reply #8 on: September 02, 2005, 11:05:23 pm »
That's how I did it.  It's pretty flat right now but it looks very even.  I can see how some people might want it a little more rounded though...
jmelan
  • Last login:March 21, 2021, 04:14:39 pm
« Reply #9 on: September 02, 2005, 11:45:30 pm »
I used bubble wrap made for packaging glasses and dishes that i had lying around after a move with a regular hammer.  The towel idea would seem to work the same way
I noticed very little denting of the t-molding, but obviously using a rubber mallet with the bubble wrap would have been optimal
LPZ
  • Last login:April 11, 2015, 01:55:21 pm
  • 2nd place is the first loser!
« Reply #10 on: September 03, 2005, 08:34:16 am »
Talking from experience, I just push it in by hand also.  When I did it the first time, I thought about using a rubber mallet, but didn't want to ruin the t-molding.  It really sucks to double buy things, when you don't take your time and do it right the first time.
Dual 50 Caliber Continuous Fire Leon Type Machine Guns......OH YEAH!!!!!
