Author Topic: How are you guys painting HAMMERITE onto MDF?!  (Read 11832 times)
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« on: August 30, 2005, 06:19:17 am »
Im at the painting stage of my cab and have my MDF primer at hand.
However for the paint I bought a black satin finish - however I would ideally like some texture, maybe a hammered finish.
Many people on this board mentioned they rolled on Hammerite hammered finish paint on their MDF however can someone confirm that this actually works, as Hammerite is a paint for METAL.
Re: How are you guys painting HAMMERITE onto MDF?!
« Reply #1 on: August 30, 2005, 06:22:54 am »
Yes it will work, as long as you have primed properly to seal the MDF.
FWIW I have used aerosol Hammerite smooth on MDF (among other things) and the finish is surprisingly good.
darthbane2k
« Reply #2 on: August 30, 2005, 06:30:33 am »
hmmm.. given me food for thought...
Whats the avantages of using hammerite smooth? for strength? theres no texture right?
Also, could this work:
1st couple coats with satin black
last coat with hammerite textured in aerosol?
Or should I just scrap my satin paint and go hammerite all the way?
« Reply #3 on: August 30, 2005, 06:40:57 am »
Just looks afaik.
That should work fine as long as they are similar based paints (try a small scrap piece first).  I would lightly sand between coats, particularly before applying the hammerite to give it a nice surface to adhere to.
darthbane2k
« Reply #4 on: August 30, 2005, 07:16:51 am »
Just looks afaik.
« Reply #5 on: August 30, 2005, 08:25:09 am »
how long does this stuff take to dry per coat?
Dunno exactly...give it plenty of time (one day) if you're sanding it.
How many coats do you reccomend (seeing that it is tougher paint than normal)
Spray cans always give a thin paint finish, so treat it pretty much as normal.  Concentrate getting a good base (primer and satin) and you should only need 1 coat of hammerite.
I normally do around 3 coats of primer (sanding between as it roughens up), and then 2 layers of topcoat on MDF.
If you use the smooth topcoat in particular, make sure you use really fine sandpaper / wet & dry between coats, or 'scratch marks' might show through the top layer of paint.
darthbane2k
« Reply #6 on: August 30, 2005, 08:52:17 am »
« Reply #7 on: August 30, 2005, 09:05:20 am »
Not sure about sanding after priming though.. I actually want a textured finish.
Priming brings up little fibres in the MDF.  Believe me you will want to rub those off (it will look & feel like ---steaming pile of meadow muffin--- otherwise).
The hammerite paint will give you a textured finish, not the wood.
darthbane2k
« Reply #8 on: August 30, 2005, 09:25:33 am »
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #9 on: August 30, 2005, 10:08:12 am »
See my profile link...
darthbane2k
« Reply #10 on: August 30, 2005, 10:36:54 am »
That finish looks sweeet on your cab!
Im definately going for this in Black.
Quick question - how many coats did you plop on?
How long does the paint take to dry?
SirPoonga
  • Puck'em Up
« Reply #11 on: August 30, 2005, 11:32:55 am »
I don't recall the specifics.
It is Rustoleum Hammered paint
http://www.rustoleum.com/Product.asp?ddf=73&frm_product_id=21&SBL=1
I think 1 or 2 coats.  It goes on thick if you use roller.  They make a spray version which I used on the monitor.  The spray version's textures is not as granular.
