Author Topic: 49 way question  (Read 1364 times)
lesserChance
  • Last login:October 08, 2010, 04:53:20 pm
  • I do my best work through the coin door
49 way question
« on: August 29, 2005, 11:16:36 pm »
So I recently Received my 49 way joystick, and I just ordered the rotary interface.  I already have an optipac is there a way to interface the rotary adapter with that or do I have to buy another interface board?  I tried to search but couldnt find an answer... sorry..
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: 49 way question
« Reply #1 on: August 30, 2005, 12:13:03 am »
I'm assuming you bought Fl0yd's mechanical rotary add-on kit for your 49-way.  The meat of that kit is a rotary 12-position electric switch.  Currently you can only interface those with a Druin's interface, or by connecting all of the contacts on the rotary switch as buttons and using Mame Analog+.  The Analog+ method only supports a few games, whereas the Druin's method works with all the mechanical rotary games.
The Optipac interfaces Optical rotary controls, like a mouse, trackball, spinner, or 360 degree steering wheel.  So it won't work for Fl0yd's kit.
lesserChance
Re: 49 way question
« Reply #2 on: August 30, 2005, 08:24:14 am »
damn... nothing like spending $125 to get a joystick working... thanks
Re: 49 way question
« Reply #3 on: August 30, 2005, 08:26:11 am »
Didn't you look into the costs before you decided on the stick!?
lesserChance
Re: 49 way question
« Reply #4 on: August 30, 2005, 09:29:24 am »
yeah, I first bought the stick and encoder for 75, and I figured that would be good enough.  Then I decided to get the rotary interface, and without really looking into it I bought that.  Now realizing I have to get the rotary encoder.  Oh well, Ill be able to play some good games now.
Lilwolf
Re: 49 way question
« Reply #5 on: August 30, 2005, 09:58:07 am »
If you have an EXTRA 12 connections in your encoder.... Then you can use analog+ mame to get 1/2 of the rotary games working perfect.
I would recommend this along with the druins board.  (druins for ikari warriors and a few that use that driver and for Xybots).
But you can get time solders running without additions cash to start off with... but druins board is really cheap (compared to everything else you've bought)
fl0yd
  • Last login:April 15, 2009, 12:24:39 am
    • Rotary Adapter for Midway 49-Way Joystick
Re: 49 way question
« Reply #6 on: August 30, 2005, 08:44:24 pm »
I just went to Happ's site and priced what it would take to use the coupler I supplied along with Happ's optical rotary interface.  In parts alone it would cost just as much or more for a druin's, as opposed to converting the mechanical into an optical.
Kremmit
  • - AHOTW -
Re: 49 way question
« Reply #7 on: August 31, 2005, 01:03:43 am »
Lilwolf forgot to read!  :P :P
Lilwolf
Re: 49 way question
« Reply #8 on: August 31, 2005, 07:57:30 am »
I was more mentioning that you should consider doing both in the long run.
And you can start with one... then add more later if money is an issue...
TimeSoldier alone can fill your rotary fix for a month before you start jonz'n for some VictRoad!
But even with a druins board.  You should consider direct connect for the others.  I really need to take a look at the driver and see if I can figure out the Ikari + analog+mame issue.
