Author Topic: Did I Fubar?  (Read 1566 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
Did I Fubar?
« on: August 29, 2005, 01:06:02 pm »
I'm in progress of building my cab.
http://forum.arcadecontrols.com/index.php?topic=41641.0
I'm done with the painting.
Problem is I wasn't sure on the T-molding.
I'm using 1/2" plywood and not handy with the tools (router).
The cab is looking nicely and I've realize that I do need some type of molding.
Am I too far in to do it?  Will it ruin the paint?
Is there another option or another type of molding I can use?
Teamwork - A group of people running around doing what I say.
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re: Did I Fubar?
« Reply #1 on: August 29, 2005, 01:12:01 pm »
Doesn't look too late to me.  A router and slot cutting bit will do the trick.  The router still has the outside of the cabinet to ride on.  Router bottoms are typically smooth plastic and should not scratch, however if you are concerned, just put down some masking tape first.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: Did I Fubar?
« Reply #2 on: August 29, 2005, 01:21:09 pm »
Yes, you didn't paint it black! ;D
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
Re: Did I Fubar?
« Reply #3 on: August 29, 2005, 01:37:39 pm »
If you are worried about scuffing the paint, lay down a few strips of masking tape for the router to ride on.
Avery
MameJunkie
  • Eeeeeeeevil
Re: Did I Fubar?
« Reply #4 on: August 29, 2005, 01:40:37 pm »
Besides worrying about the paint, I was more worried about ripping the corners off.
If I ruined a piece before I put it together, it would have been easier to deal with.  But IF I was to damage the side pieces now, I might shoot myself.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Did I Fubar?
« Reply #5 on: August 29, 2005, 01:43:02 pm »
Test. test test on a srcap piece of wood (same type of wood) before you put the router on your cabinet.
I think you should be fine.  But I'm not sure if or where you'll find 1/2" t-molding.  tmolding.com?
KungFuJoe
  • Last login:February 05, 2006, 05:10:10 am
Re: Did I Fubar?
« Reply #6 on: August 29, 2005, 02:21:23 pm »
Masking tape for sure.  But I would definitely lay the cabinet on its side before doing the routing....
MameJunkie
  • Eeeeeeeevil
Re: Did I Fubar?
« Reply #7 on: August 29, 2005, 02:23:34 pm »
www.t-molding.com had 1/2" in black or white.
I'll probably use black
romperwomb
  • Last login:May 24, 2023, 06:07:43 pm
  • Plick!
Re: Did I Fubar?
« Reply #8 on: August 29, 2005, 02:36:16 pm »
Wow, I really like your cab.  I also went with DK jr. Orange on my cab.  The DK Jr.'s had white molding and it really makes the Orange *POP*.
skid_68
  • Last login:December 29, 2022, 07:25:30 pm
  • Hmmmmmmmm....
Re: Did I Fubar?
« Reply #9 on: August 29, 2005, 07:57:25 pm »
I agree, I wouldnt go with black t-molding. White would be a better match.
Great looking cab so far. :)
