Main > Main Forum
Time Crisis question ...
RayB:
OK well, Time Crisis 1 plays on a single monitor, so there's no reason to worry about it.
JB:
--- Quote from: Pik4chu on August 19, 2005, 08:51:56 pm ---
--- Quote from: RayB on August 19, 2005, 08:13:27 pm ---Two monitors?
two monitors being, on time crisis II and newer the 2 player setups had either a sindle (SD) or dual (DX) monitor setup. allowing for much larger play area in the arcade version. Basically his question is, will the mame'd time crisis be able to do two monitors. And for a guess I would say, proly not.
It doesn't allow a larger play area. It allows 2 players. And as far as I know, it's actually 2 totally seperate machines in one cabinet.
Pik4chu:
--- Quote from: JB on August 21, 2005, 02:14:42 pm ---
JB:
--- Quote from: Pik4chu on August 21, 2005, 02:56:11 pm ---
sora mispoke myself, what I meant by larger area is just that two players dont have to share the same monitor and stand so close to each other.
[/qote]
Ah.
Also gives each player a first-person view of the action. If they shared a screen, they'd have to use the same viewpoint.
--- Quote ---And it is my understanding that the arcade cabs were just a single board specially designed for two monitors/guns/players. But since Ive never seenm inside one I cant be sure. Though it doesn't really matter :)
*shrugs*
I thought it was 2 boards, but I may very well be mistaken.
It may turn out to matter, though.
If it uses 2 boards with one driving each screen and a comm cable connecting them, the cost to emulate goes way up over the other System 23 games.
PedroSilva:
I know very well time crisis II (I've already finished it
