Author Topic: Help with Oscar Volume Knob Project...  (Read 1603 times)
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« on: August 12, 2005, 01:34:34 am »
I purchased the same Radio Shack potentiometer (271-1732) that Oscar shows in his instructions here:
http://www.oscarcontrols.com/volume/
After following the instructions, i connected up the new volume knob between my sound card and amp input.
The problem is that I only get sound over a TINY range (~10 degrees) of the potentiometer.
Does this sound like a wiring problem...  bad pot... wrong pot...
Any ideas?
Rocky
Re: Help with Oscar Volume Knob Project...
« Reply #1 on: August 12, 2005, 09:29:48 am »
Do you have the sound card volume at maximum?
tivogre
    • ogredog.com
« Reply #2 on: August 12, 2005, 02:34:19 pm »
Yes.  It's at maximum.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: August 12, 2005, 04:38:35 pm »
You still need an amp. Potentiometers won't amplify the signal for you.
If the sound is amped, then is it possible you connected the wires wrong? POTs have 3 prongs (usually). Maybe you're using the wrong two?
NO MORE!!
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #4 on: August 12, 2005, 06:56:56 pm »
The way a potentiometer works is you have two leads separated by the resistive material, and one lead that works as a 'tap' to pick off the voltage from an arbitrary point on the resistive element.  So if you have two leads connected, there are only two options.  Option 1:  connection to the input and output (not using the tap).  This will function as a normal resistor, and the knob won't do anything so long as the tap is floating and unconnected.  Option 2:  Connection to either the input+tap or the output+tap.  In either case, the potentiometer will function, but the direction you turn the knob to ramp up the resistance changes dependent upon which way you have connected it.
So you do  have your pot connected correctly, since you are hearing a change with turning the knob.  If I were you I would follow Ray B's advice and look into picking up a small amp.   Of course, if you do have an amp hooked up, maybe you got a potentiometer that is way too big in resistance.. that would explain a small operating range as well.
Where did you decide to mount your volume knob anyway?  I'm looking for ideas on where to put one myself.. it would sure beat running around to the back of the cabinet to adjust it from game to game!  :)
Let us know how it turns out..
-88mph
« Last Edit: August 12, 2005, 06:58:50 pm by 88mph »
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #5 on: August 13, 2005, 12:04:52 am »
-- Chad Tower
tivogre
    • ogredog.com
« Reply #6 on: August 13, 2005, 12:20:02 am »
Well...
Turns out I didn't have a problem after all!
I was trying to test my new volume knob using a cheap portable CD player and headphones before hooking it up to my much more expensive sound card and speakers.
After checking the wiring and the pot using my multimeter, I took a chance and hooked it up between the sound card and speakers.
SUCCESS!
Apparently, the CD player has much less output to work with than the sound card... even at full volume.
The new volume knob works GREAT!
Here it is:
I updated my web site with photos and details of assembling the volume knob:
http://www.ogredog.com/mame_construction_home.htm#Day%2050
Thanks to everyone who tried to help!
« Last Edit: August 13, 2005, 01:49:19 am by tivogre »
tivogre
    • ogredog.com
« Reply #7 on: August 13, 2005, 09:28:54 am »
Anybody just try something like this $4 item:
http://www.amazon.com/exec/obidos/tg/detail/-/B00006HSHM/qid=1123905798/
My speaker system already has a wired "remote".  I wanted a solution that I could easily panel mount so that all you see is a knob.
