Author Topic: Removing Tamper Proof Star Screws...  (Read 2782 times)
Sinner
  • Last login:May 05, 2020, 06:22:06 pm
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« on: August 08, 2005, 01:14:55 pm »
Does anyone have a tip for removing the Tamper Resistant Sar screws out of a unit, if you don't have access to the proper tool...I was thinking of trying to drill out the pin and using a regular alan/star hey, but I'm not sure if it would be possible...
Any ideas?
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re: Removing Tamper Proof Star Screws...
« Reply #1 on: August 08, 2005, 01:16:17 pm »
Yup, you can drill it out
-- Chad Tower
Sinner
    • Geek My Gadget
« Reply #2 on: August 08, 2005, 01:21:12 pm »
Kewl, I will give it a try tonight...do I drill out the pin or whole screw?
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #3 on: August 08, 2005, 01:23:27 pm »
Just drill out the pin
first off your and idiot
quarterback
« Reply #4 on: August 08, 2005, 01:24:34 pm »
-- Chad Tower
Sinner
    • Geek My Gadget
« Reply #5 on: August 08, 2005, 01:29:06 pm »
Great...I'm not too steady, or good with the tools, but I'll give it a go...thank you.
PetitMorte
  • Last login:December 11, 2015, 10:03:43 am
« Reply #6 on: August 08, 2005, 01:31:54 pm »
I use a good set of vise-grip pliers to grab the screw head from the sides and then unscrew it.
if that doesn't work, you can also use a dremel with a cutting disk to cut a slot in the head and use a standard flathead screwdriver to unscrew it.  If you have no dremel, a hacksaw will make the slot too.
Bitten by the cabinet bug... obsessing ever since.
pointdablame
« Reply #7 on: August 08, 2005, 01:32:40 pm »
Find a drill bit that is JUST smaller than the area within the hex/torx.  Go very slow, and try not to rub out the star/hexagon design so that you can use a hex/torx key after.
Or.. if they aren't very tight, you could always try to ol BIC pen trick... they'll probably be too tight for that tho.
quarterback
« Reply #8 on: August 08, 2005, 01:32:53 pm »
In my experience, it's not that tough.
-- Chad Tower
Sinner
    • Geek My Gadget
« Reply #9 on: August 08, 2005, 01:36:10 pm »
Sweet...I have hope of getting these stupid things out tonight...this is my first cab, and I'm trying to take my time, so I don't end up breaking things...I don't want to do something stupid...
Thanks for the tips...
quarterback
« Reply #10 on: August 08, 2005, 01:39:15 pm »
The other thing you could do is to buy some tamper proof bits :D
I got mine for ~$5 off eBay, but I later found them at Sears.
The thing about Sears was that nobody knew they had them AND the package wasn't even labled as being tamper-proof.  I just happened to pick up a set of torx bits there, looked at the tips through the plastic and saw that they were hollow.    DOH!
-- Chad Tower
Sinner
    • Geek My Gadget
« Reply #11 on: August 08, 2005, 01:42:26 pm »
quarterback
« Reply #12 on: August 08, 2005, 01:47:50 pm »
Kewl...was that a Sears in Canada??
-- Chad Tower
Sinner
    • Geek My Gadget
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:37:55 pm
« Reply #14 on: August 08, 2005, 01:55:22 pm »
either drill the pin out or drill a hole on the allen wrench  :D
Free VGA Breakout Cable
Sinner
    • Geek My Gadget
« Reply #15 on: August 08, 2005, 01:59:06 pm »
AlanS17
    • AlanS17
« Reply #16 on: August 08, 2005, 02:29:32 pm »
If the screw head is exposed, cutting a slow is a snap. Finding those bits isn't particularly difficult, though. I would think you could get a bit set or even a proper star screw driver pretty easily. Sometimes it doesn't hurt to actually do things the right way.
Sinner
    • Geek My Gadget
« Reply #17 on: August 08, 2005, 02:36:06 pm »
What is a BigLots??
I was hoping to get this done tonight, that's why I was looking for some way to do it without having to wait until I could get the proper tool...I want to remove the old board that hold the speakers (mono), and mount a new board, with a set of Sony X-Plod speakers...
I think we have Lowes coming here, but for now, only Home Depot exists...
Sinner
    • Geek My Gadget
« Reply #18 on: August 08, 2005, 11:16:23 pm »
I used my dremel and a cutting disc to cut a slot into each screw, adn it worked great...
Thanks to all for the tips...
