Author Topic: a couple of question for those who use tv's as monitors  (Read 1666 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: August 06, 2005, 12:35:04 am »
Hi. I was at walmart and i saw that they have 20 inch TVs with s video jacks. I think they were made by Emerson. Wouldn't it hurt your eyes using a TV being that your only 2 feet away from it? I have heard that some people have a issue with flickering. What is  the reason for this ? I'm currently using a geforce 6800 card. I like to keep my cab running during the day and shut it down at night. Wouldn't it be bad to leave a TV running that much especially in a cab?  ???
any info would be greatly appreciated
thanks
rlemmon
Re: a couple of question for those who use tv's as monitors
« Reply #1 on: August 06, 2005, 08:36:13 am »
Anybody out there  :(
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: August 06, 2005, 08:42:37 am »
I'm here ... I just don't use a TV in my cabinet ... sorry ...
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
NoOne=NBA=
« Reply #3 on: August 06, 2005, 08:55:17 am »
The main reason you see warnings on video games, is that certain flashing in video games can (in rare cases) trigger epileptic seizures.
It's not actually the flickering on the display that causes it, IIRC.
It will definitely accelerate wear on it, but shouldn't hurt it.
If you think about all the TV's that are left on 18 hrs. a day at bars and such, you'll probably be a little less worried.
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #4 on: August 06, 2005, 06:45:08 pm »
I have had a TV going in my cabinet all the time. No problem. It's not any worse on my eyes than a computer monitor, and it makes the pixel edges a little softer and nicer when playing games. It's a good compromise between a monitor and an arcade monitor as far as I'm concerned, though that varies from person to person. As for damaging it. Nah. TVs are meant to be used over many, many hours.
One thing I would suggest is... get a TV with an auto on after power off feature. Makes it much easier to start up and shut down the cab.
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
« Reply #5 on: August 06, 2005, 11:40:32 pm »
heck i leave a  tv weeks at a time. no problem with mine
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #6 on: August 07, 2005, 12:07:40 am »
I have a 27" flat panel and it is great.  Not as crisp as a monitor, but I am very happy with the looks.  Three factors I considered were, 1) total width of t.v. so it would fit in my cab okay, 2) Auto on after power off so it would work with my power strip, and 3rd) it had to have s video, it makes a big difference over composite.  Doesn't hurt my eyes at all, other than trying to read fine print  :o
Q*Bert_OP
  • Oh yes, we did!
« Reply #7 on: August 07, 2005, 12:39:32 am »
I have a 27'' tv that I use with a mame cab setup running windows, and the pixels on the tv are so big, you cant see the text....also in games like Pac man, the maze flickers alot  :-\
vornar
  • Last login:July 05, 2008, 12:48:31 am
« Reply #8 on: August 07, 2005, 12:45:30 am »
I have a 27" TV with S-Video and i think it looks great. For those on a budget it is the most realistic picture. The only problem with mine is that it will auto power on when the power is applied but it always goes back to the t.v. channels instead of the S-Video channel >:( ???
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #9 on: August 07, 2005, 02:05:42 am »
In my MAME cab I use a 24" Sony which has Component Inputs.  All games are running at 640x432 15Hz refresh.  When I compare this display with a Medium Res Wells Garner I can say that they look almost identical.  Maybe the monitor in my SuperSprint is old but the TV is actually brighter and has more contrast.
The bad thing is that 640x432 is almost useless for windows XP Gui.  You'll need a standard VGA monitor or connect the TV to S-VIDEO to use windows during maintenance or setup.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
rlemmon
« Reply #10 on: August 07, 2005, 04:16:33 am »
thanks for the help guys :)
jcroach
  • Last login:March 01, 2012, 09:36:56 am
« Reply #11 on: August 16, 2005, 10:39:46 am »
Hey guys, what models or manufacturers support "auto on after power off"?
Sensei
  • Last login:May 03, 2008, 11:30:58 am
  • Take this pebble from my hand.
« Reply #12 on: August 16, 2005, 10:50:49 am »
I have always used a tv.
I have a 27" Prima television with s-video.
I couldn't find a television with BOTH auto-on/off AND remebering the last channel.  So either way I would have to grab the remote.
So I opted for the cheaper television with just remembering the last channel. (for the s-video input).
I have been very pleased.  A friend of mine has a 19" CRT monitor in his arcade cab and I personally like the larger size of the television.   His front-end is easier to read (but mine is still quite usuable) but the games dont present much differently....other than of course... smaller :)
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #13 on: August 16, 2005, 11:44:32 am »
I have a Sansui (cheap brand) 27".  It does not auto-on, but it does remember to always power-on to S-video.
Looks pretty good, although it displays some classic color bleeding problems (mostly with reds).
kickngas
  • Last login:April 19, 2017, 12:29:04 pm
  • "You get my Cheez Whiz boy"?
« Reply #14 on: August 16, 2005, 12:49:38 pm »
I have a 27" ESA from Circuit City and it powers up with my cabinet(Smart Strip), also remembers to go to S-Video.  Love the size, but I have to make the windows font huge in order to read. Most games really look great...close to original arcade monitors.  Also, some colors, especially blue, in vector games are not too clear.  I am looking for a 24 or 27" presentation monitor to replace the TV.  Can't beat the TV for price, but I personally like the clarity of a monitor.
pcates
  • Last login:January 05, 2011, 08:15:57 pm
« Reply #15 on: August 16, 2005, 02:11:12 pm »
Powering on/off is not really a big deal. I just keep the remote on top of the cab and turn it on when I want to use it, and off when I am done. Takes 2 extra seconds. I leave the computer on all  the time.
As far as quality, I have the TV running side by side with a Comp monitor and you can see huge differences in the windows environment/text, but in game play the tv looks great.
Patrick
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« Reply #16 on: August 16, 2005, 03:42:19 pm »
Durabrand from walmart does both. It remembers it's last power state when power is removed, and also stays on the svideo input. Mine is dedicated to my cab and has been so reliable that I don't even know where the remote is anymore.
It's made by Sansui I belive, tube is curved for that "old school" feel, and the price is right - my 27" was $168 US.
Scoobie
  • Last login:April 03, 2024, 04:22:53 pm
« Reply #17 on: August 16, 2005, 04:48:30 pm »
The Toshiba 27" is a good bet.
ahofle
    • Arcade Ambience Project
« Reply #18 on: August 16, 2005, 05:42:51 pm »
Not to change the subject, but how much better is component input than S-Video?
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« Reply #19 on: August 16, 2005, 05:47:58 pm »
Mine has the same color bleeding but it's mostly with blues.  Does anyone know if this can be fixed?
jhanson
« Reply #20 on: August 16, 2005, 06:14:59 pm »
I have a 20" Panasonic TV in my cabinet.  It uses s-video.  I think it looks very good, and have never had any complaints.  Very small text is a bit hard to read, but that's about it.  You can see pics of my cabinet here.
Scoobie
« Reply #21 on: August 16, 2005, 07:47:44 pm »
Component is significantly sharper than s-video, however you will need a dongle (at least that's the way I needed to go) if you have an ATI video card.
Keep in mind that a standard def tv (even with component) won't look as clear as a computer monitor or HDTV, but still better than s-video.
Sensei
« Reply #22 on: August 16, 2005, 09:17:20 pm »
I think perhaps you mean composite as opposed to component.
Going from worst to best it goes:
coaxial -> composite (or RCA) -> s-video -> component (where you have an input for each primary video color) -> digital (like VGA or HDMI)
I find going from composite (or RCA) to s-video the picture is slightly sharper with less color bleedin and a lot less interference.  Sometimes you wont notice it (say with fast moving game images) but where you'll notice it is when there is high contrast (say with a lot of black on the screen).  You may notice interference (looks like faint lines waving in the black color) or bleeding (usually dark colors will cross over into light color areas).
Most recent video cards have s-video as an output option as do most relatively new tv's.  I say if you have the option do it.
Hey every little bit helps.
Scoobie
« Reply #23 on: August 16, 2005, 11:44:07 pm »
Since component gives a better picture than composite and s-video, I think ahofle was asking about component... ;D
