Main > Project Announcements
Anyone ever gone this BIG???
Harpal:
--- Quote from: ChadTower on January 24, 2006, 12:55:02 pm ---
Forget behind the seat... crank those solenoids up and put it IN the seat.
now thats a good idea ;)
flyguy1821:
Update -
I have started on the project again. So far I have constructed most of the outer shell for the "front" which will hold the tvs and most electronics. I have also doubled the number of casters for the base, figured I would do it now before assembly. A little overkill, each caster is rated for 200lbs and I now have 22 of them.
shardian:
I was just thinking...if you go all out, the artwork alone for that monster will cost over $1000 probably..
Man I wish I had your fundage. ;D
flyguy1821:
It has been fused together!!
flyguy1821:
I was able to get a couple more sheets of MDF and finished the bottom support for the TVs. Rather big moment seeing it come together for rough form. Only the front panels to cover the TVs, kickboards, the back of the front portion and marquee housing and construction will be complete. Next step will be the wiring process. I placed my seats back in just to get a good feel and make sure everything is layed out correctly. Pretty dust since they have been sitting for about 6 months.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
