Author Topic: CONTROL PANEL COVERING  (Read 980 times)
edwardvci
  • Last login:February 23, 2009, 08:56:49 pm
  • Insert Coin.........!
« on: August 03, 2005, 11:47:41 pm »
I am starting a new cab and was thinking about using BAND-IT BLACK MELAMINE 24" X 96" IRON-ON to cover the control panel and was wondering if any of you had used this. And if so how well did this work. My control panel is going to be 18X48.
http://www.partsexpress.com/pe/showdetl.cfm?&Did=7&Product_ID=171416
AlanS17
    • AlanS17
Re: CONTROL PANEL COVERING
« Reply #1 on: August 04, 2005, 12:32:38 am »
I would expect it to do fairly well, but I don't know if it would start to come up around the edges or not. I'm pretty sure some of the commercial pre-built control panels use melamine. I don't know what brand or applicaation method they use, though. Heck, they might even use pre-coated MDF.
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #2 on: August 04, 2005, 12:33:10 am »
I can't say anything about that in particular, but a lot of people, including myself, have used the adhesive vinyl from PartsExpress with a lot of success.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-018
I know it's not exactly the answer you were looking for, but it may be worth considering.  It's cheaper than the melamine, a bit easier to apply IMO, and holds up really nicely on a CP.
first off your and idiot
AlanS17
    • AlanS17
« Reply #3 on: August 04, 2005, 12:35:02 am »
If you're looking to spend that much, you might also want to consider laminate (like Formica). It's not that much more and it's virtually indestructible.
pointdablame
« Reply #4 on: August 04, 2005, 12:38:43 am »
Good point.  My local Home Depot has laminate right in store.  I think the prices were $25ish and $45ish, for something like 2' x 4' and 4' x 8' sheets respectively.
AlanS17
    • AlanS17
« Reply #5 on: August 04, 2005, 12:41:33 am »
Yup, and they carry it in black, too.
