Author Topic: Single, most compatible joystick?  (Read 2575 times)
spystyle
« on: August 03, 2005, 11:34:41 am »
Howdy,
Is there a joystick that handles 2,4,8 and analog, and can rotate?
Probably not
But, what joystick comes close? Is there a single joystick that is most compatible with all of MAME's games?
(Right now I'm just using an 8-way)
Has anyone invented an electronic 4/8/analog switch? That would be cool.
Thanks,
Craig
AlanS17
    • AlanS17
Re: Single, most compatible joystick?
« Reply #1 on: August 03, 2005, 11:45:06 am »
49-way joystick with rotary attachment
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #2 on: August 03, 2005, 02:37:08 pm »
conseit68
  • Will sell anything that isn't nailed down...
  • Last login:February 12, 2020, 10:52:27 pm
  • Back to the Future Cab...In Progress
« Reply #3 on: August 03, 2005, 02:39:37 pm »
yeah...what they said :)
spystyle
« Reply #4 on: August 03, 2005, 04:26:29 pm »
Thank you :)
Do you recommend a particular brand or should I just Google it?
AlanS17
    • AlanS17
« Reply #5 on: August 03, 2005, 04:31:38 pm »
Search the threads in the Main forum. It's a popular topic. You can browse and find it.
spystyle
« Reply #6 on: August 03, 2005, 04:37:52 pm »
Thanks again.
I have a Pac-Man (with only 1 stick) while sorting my ROMs I started to wonder if there was 1 that could handle all of them.
Have fun,
Craig
NoOne=NBA=
« Reply #7 on: August 03, 2005, 05:10:19 pm »
Thank you :)
It depends on what you really want.
If you have to have a rotating 49-way, the Happ style is the only one available at the moment.
I personally don't care for them because they feel too floppy to me.
The Williams style has more resistance to it, but possibly a little TOO much at the extremes of travel.
I prefer the overall feel of them to the Happ ones, but they are a little harder to control subtly.
As far as the encoder goes, Groovy Game Gear is the only game in town on that.
DaveB has a 49-way encoder, which works great for 49-way and most analog games.
It doesn't do the digital restriction that the GGG one does though.
Tiger-Heli
    • Tiger-Heli
AlanS17
    • AlanS17
« Reply #9 on: August 03, 2005, 05:20:39 pm »
The joystick bolt pattern for the metal control panel on your Pac Man is not going to match up. Do you plan on converting an original Pac Man for MAME?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #10 on: August 03, 2005, 05:39:31 pm »
Oh ... say it isn't so ...
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
AlanS17
    • AlanS17
« Reply #11 on: August 03, 2005, 05:54:16 pm »
Yeah, I've already got my hand swung back over here.  ;)
spystyle
« Reply #12 on: August 03, 2005, 06:36:28 pm »
Thank you all for the information and recommendations. You've saved me much time :)
As for chopping a Pac-Man up : mine, ofcourse, is scratch built!
Now to read those links...
Have a nice day,
Craig
« Last Edit: August 03, 2005, 07:34:27 pm by spystyle »
AlanS17
    • AlanS17
« Reply #13 on: August 03, 2005, 07:01:31 pm »
AH! A sigh of relief...  :)
If you want to buy one new you'll probably have to go with the Happ joystick. The rotary attachment is designed for that particular stick too, I believe.
I'm pretty sure there are aftermarket ball-top shaft replacements. You might consider that approach if you want to keep that classic feel.
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: August 04, 2005, 08:39:14 am »
I like the yellow PC in the pac-man cab to keep it "themed".   8)
nostrebor
  • SHOCKING!!
« Reply #15 on: August 04, 2005, 09:43:22 am »
Your speaker is WAY too small!
