Author Topic: What games actually use caps/num/scroll lock lights?  (Read 971 times)
AlanS17
    • AlanS17
« on: July 26, 2005, 11:30:42 pm »
I'm trying to decide if I should wire up my new machine for the caps/num/scroll lock lights. Right now I'm leaning towards "no", but I've never used them in a machine before have considered giving them a shot. Does anybody have a list of games?
This is for a vertical cocktail to play mostly classic games.
SirPeale
  • Green Mountain Man
Re: What games actually use caps/num/scroll lock lights?
« Reply #1 on: July 27, 2005, 06:35:38 am »
Hm...I know Pac Man and a lot of the Midway games use them.
APB uses one for the brake light, IIRC.
AlanS17
    • AlanS17
« Reply #2 on: July 27, 2005, 08:50:47 am »
How are they used? Drop in a coin and the start button lights up?
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: July 27, 2005, 08:55:20 am »
Nope, I think the latest builds took them out of PacMan.  Not sure about APB.
Most of the early Atari stuff has them.  Asteroid, bzone, probably centiped, milliped, redbaron, digdug, gravitar.
Scroll lock - OutRun uses it for the brake.  Ajax uses it for the special weapon.  Spy Hunter SHOULD use it for the weapons van, but doesn't.
Personally, if you were leaning towards not having them, I would stay with that impulse.  I think they are cool, but for the few games that use them, I wouldn't worry too much about adding them again.
REPLY #3 -
In MAME, generally Num Lock flashes when 1 credit is inserted (simulates the flashing 1P start volcano lights on early Atari games), NumLock and Scroll Lock flash when 2 credits are inserted (simulates the 2p start volcano buttons.
Buddabing
« Reply #4 on: July 27, 2005, 09:13:17 am »
Please read the wiki!
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #5 on: July 27, 2005, 09:44:27 am »
Pretty much every classic atari game, asteroids, dig dug, lunar lander, tempest, etc...
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #6 on: July 27, 2005, 09:55:25 am »
I have the NUM and CAPS LEDs in my coin door. They're set to blink in sequence for everygame when a token is deposited, and stay lit once a start button has been pressed.
I also have Scroll Lock controlling coin lockouts on my coin mechs, and set it to only light when a game has started, to stop my wife whining when she puts in a token in the frontend and nothing happens; now if you put a token in when the frontend is running it comes out the coin-return.
I was using Scroll Lock to control a couple of cold cathode lights behind my control panels, but it wasn't as nice as I had hoped so I thought I'd try the coin-lockouts and they work great!
