Main > Monitor/Video Forum
VCR to D9200
dabone:
I'd imagine it's because he would like to be able to watch tv with having to run the
computer.
(It's also a easy way of hooking up a xbox, ps2, etc to the 9200)
Later,
dabone
paigeoliver:
--- Quote from: dabone on July 19, 2005, 04:54:10 pm ---I'd imagine it's because he would like to be able to watch tv with having to run the
computer.
Later,
dabone
EXACTLY.
richms:
The problem with using a PCI or USB tuner is there is a delay in the display. We were seeing a 2-3 field delay when comparing a PC tv tuner with a TV connected to the same source. This is unacceptable for gaming.
quadmasta:
See if you can find a converter that converts NTFS to PAL. I'm pretty sure PAL will display on the monitor through SCART.
Silverwind:
--- Quote from: richms on July 23, 2005, 12:04:02 am ---The problem with using a PCI or USB tuner is there is a delay in the display. We were seeing a 2-3 field delay when comparing a PC tv tuner with a TV connected to the same source. This is unacceptable for gaming.
I have played PS1 through my tv tuner and it ran great. For some reason cable TV feeds have a split second delay, and I'm not sure why. The quality is still good IE no stuttering but it is a split second behind a regular TV.
http://www.starkelectronic.com/vga300.htm
that sort of gives you an idea of a converter.. it is more expensive than a simple gender changer...
