Main > Main Forum
Analog to Dual-Strike USB writeup!
Pages: << < (2/6) > >>
Lilwolf:
Bump!
(yes this needs to be added to the examples Saint!)
And I just won my first analog joystick on ebay yesterday!!!
BECAUSE NOBODY ELSE BID!!!
$175 happs flight stick for 10 bucks!  And I think I might spend the cash to get the right hand handle for 20 from happs and I will be happy!
btw, a GREAT place to get a DualStrike is on ebay.  They are going between 5 - 9 bucks without shipping.
btw, 1UP, you might consider adding one more thing to your writeup (since I believe you mentioned it worked before) is add the hotswap ability (it does work right?).  Best part about the hotswap, is if you ignore the buttons, then you can get both on a 9pin serial plugs.
1UP:
--- Quote ---btw, 1UP, you might consider adding one more thing to your writeup (since I believe you mentioned it worked before) is add the hotswap ability (it does work right?).
SirPoonga:
Those wires underneith the left/right pot wires are the buttons on the left part of the gamepad?
Mame should see those buttons on the right hand normally, right?  Through DirectInput?
1UP:
--- Quote ---Those wires underneith the left/right pot wires are the buttons on the left part of the gamepad?
SirPoonga:
Yeah, I know, just asking.
I like the idea of the positional gun.  Does it aim correctly at all areas of the screen?  even where most joysticks have a "deadzone"?
Urebel showed my hte directx code in mame that I can set the deadzone to 0.  if I can hacka  positional gun (fancy joystick) to mame then I could get it to work with all mame games by acting like a mouse too.
Anyway, I'd rather have the act labs solution if they make it.
Go to full version
