Author Topic: problem with ground wire hook up  (Read 960 times)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
« on: July 17, 2005, 10:00:05 pm »
ok im trying to wire up my control panel right now, its a two player control panel with 6 buttons each player, im using a IPAC2 and my question is: do i wire player 1 controls separate than player 2s controls? on the IPAC2 there are 2 ground connections? 1 for each player right?
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
testicle187
  • Last login:September 21, 2022, 09:34:53 am
Re: problem with ground wire hook up
« Reply #1 on: July 17, 2005, 10:27:54 pm »
You can wire them all together through one ground, or use seperates for each player.
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: July 17, 2005, 10:28:09 pm »
It doesen't matter if you use 1 or both it all works by personal experiance, and my lazyness to not have to do seperate daisy chains :-X
« Last Edit: July 17, 2005, 10:51:12 pm by qbert247 »
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #3 on: July 17, 2005, 10:29:38 pm »
On the minipac you simply daisy chain all of the grounds from each switch.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
joshbr7257
« Reply #4 on: July 17, 2005, 10:59:26 pm »
thanks for the info, but i dont really understand what daisy chain? is, dont i just have to put 2 wires in each disconnect and create a wire harness? is that the same thing. ??? im trying to follow it in the spystyle guide below:
http://spystyle.arcadecontrols.com/index8.htm
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
« Reply #5 on: July 18, 2005, 03:31:37 am »
The instructions for daisy chaining are right at the middle of the page you linked.
A picture of an imaginary green wire passing through all buttons. Then the actual crimping 2 wires together into a single connector to get it done.
An ounce of image is worth a pound of performance.
joshbr7257
« Reply #6 on: July 18, 2005, 06:45:44 pm »
yeah i had a feeling that it was daisy chaining, but it didnt say that so i didnt know thanks, so i guess i will just daisy chain all of the buttons together player 1 and player 2, thanks for the help ;)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: July 18, 2005, 06:55:53 pm »
The advantages of keeping them seperate is that you could decide to mess around with one of the sets and yet still be able to play with the other one.....
NO MORE!!
joshbr7257
« Reply #8 on: July 18, 2005, 07:01:14 pm »
yeah im still thinkingabout doing separate im going to start on it inthe next few minutes but, so your saying its better to wire them separate?
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: July 19, 2005, 07:41:07 am »
If you wire them in one big loop - I-PAC Gnd to button 1 to button 2 to . . . and back to I-PAC Gnd, then you have to have two breaks in the gnd wire before you will even notice it.  If you wire them separate, you will have a shorter run to troubleshoot if you ever have problems.  Your call.
joshbr7257
« Reply #10 on: July 19, 2005, 01:06:02 pm »
lol, well its too late i just wired them all up into 1 ground port  ;D
