Author Topic: mouse buttons on CP...yes or no?  (Read 872 times)
sdrob04
  • Last login:February 18, 2021, 02:12:50 pm
« on: July 13, 2005, 11:44:10 am »
Rather than taking a poll, can those who have strong feelings one way or another share their experiences with having/not having mouse buttons on the control panel?
crashwg
Re: mouse buttons on CP...yes or no?
« Reply #1 on: July 13, 2005, 12:00:07 pm »
Mame sees the left mouse button as button one, therefore you could wire it up as your first button and have the functionality of a mouse button without adding extra buttons.  Only problem I see with a setup like that is emulators that you wouldn't be able to set up mouse buttons for.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #2 on: July 13, 2005, 02:23:16 pm »
I've never been into the idea of dedicated mouse buttons on a CP.  Seems like a waste of space to me and doesn't seem 'authentic'.   I mapped the mouse buttons as my player 2 fire buttons and left it at that.
Similarly, my admin buttons are tiny ones from RShack and are hanging off the underside of my cp, up near the monitor.  You can't see them and I like it that way.  I don't need to see them, I know by 'feel' which button is which.  I have 4 mounted but only 3 hooked up, they're: Esc, 5 and P (for exit, coin and pause)
Also, looking at your CP, your 7th button seems to be in an odd place underneath all the others.  I think I'd accidentally hit it with my palm while utilizing the others.   YMMV, I guess.
-- Chad Tower
Chris
    • Chris's MAME Cabinet
« Reply #3 on: July 13, 2005, 02:30:23 pm »
I have dedicated mouse buttons on mine, on either side of the trackball.  Since my trackball is not in line with the other buttons, these make useful buttons for games like Centipede that require a fire button, or the Golden Tee or bowling games that have "left/right" buttons.
The only game that really suffers is Missile Command.
--Chris
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« Reply #4 on: July 13, 2005, 02:52:30 pm »
I'd say no for dedicated buttons all together with the exception of exit.  PaigeOliver suggested using P1 and P2 buttons for mouse 1 and 2 and I'm glad I took the advice because it works perfectly.
Bones
  • [Moderator]
« Reply #5 on: July 13, 2005, 09:41:32 pm »
I went for 3 dedicated mouse buttons mounted near my trackball.
I don't feel it looks out of place but then my CP is a little bigger than most so space wasn't really any issue, if anything it helped balance out the appearance of my control panel.
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #6 on: July 14, 2005, 01:45:58 pm »
I don't know if this problem still exists, but back int he days when I made my cabinet mame had issues with mixing mouse and buttons controls.  In some fighters and toobin you couldn't hit two buttons, one being a mouse, one being a keyboard, and be able to work.  There was like a slight delay int he processing of the two or something.
What I did was make a switch to switch player 1 button 1 and 2 to mouse buttons.
I have a wiring diagram for a dpdt relay...
