Author Topic: IPAC with CP buttons and Joystick  (Read 831 times)
jffyoung
  • Last login:July 11, 2005, 11:53:53 pm
« on: July 11, 2005, 02:50:09 am »
I am aware of a few shortcuts using the joystick and a few CP buttons (instead of the keyboard):
Player1 + Player 2 = Exit
Left on joystick then right on joystick = go past ok screen
Player 1 + down = Tab
Blah blah blah...
But is there a combination for when you are in the <tab>input area for <enter>? How do you emulate the enter key?
Also, is there a complete list of the combinations anywhere?
-Jeff
Bones
  • [Moderator]
Re: IPAC with CP buttons and Joystick
« Reply #1 on: July 11, 2005, 02:57:31 am »
The default "straight out of the box" programmed keys can be found here.
http://www.ultimarc.com/ipac2.html
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #2 on: July 11, 2005, 10:01:48 am »
Disabling the p1 / p2 exit was one of the best things I ever did. :)
markrvp
  • NFL Expert
« Reply #3 on: July 11, 2005, 11:11:48 am »
It appears from that chart that enter would be    P1 START + JOYSTICK LEFT
jffyoung
« Reply #4 on: July 11, 2005, 07:03:22 pm »
I own the IPAC4 player. Is the Player 1 + <anykey> the same on both the 2 and 4 player versions? I.E. Would the Player 1 + P1 Joystick Left = Enter?
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: July 12, 2005, 08:46:01 am »
Yes, but on the 4-player version, you also have a separate shift button that shifts the Player 3 and 4 keys, but it's up to you if you want to use it or not.
