Author Topic: "dirty" potentiometers?? (with AKI )  (Read 1683 times)
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« on: July 07, 2005, 01:40:20 am »
I have the spring loaded pots from a world series cp and I bought the AKI from Dave.  I believe I have wired them correctly to both X and Y axis' then grounded the Z axis as specified for unused axis'.
But my problem is, when I calibrate the controls, they seem to flicker around and don't seem to want to go to their extreme positions consistently.  Is there some kind of pot maintenance/cleaning that my controls need?
I am 100% sure it is wired correctly so I'm thinking it's the pots or something related to them.
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
Lilwolf
Re: "dirty" potentiometers?? (with AKI )
« Reply #1 on: July 07, 2005, 07:53:45 am »
I had the same problem in beta.  We tried changing the timing of the polling and this and that.  It ended up that I needed to rewire the stick itself and the problems went away... and that I needed to ground (or unground) to the chassy I can't remember.
but if anyone knows how to clean a pot.  I would love to hear.
Brunnen-G
  • Last login:April 23, 2010, 09:26:00 am
  • Need more space
Side Arms, Slam Dunk, Xybots, Arachnid Galaxy darts, Pac Man Plus, Dr. Who, Gauntlet, Centipede cocktail, Hyperball, Tempest, Star Wars, Xevious, Super Hang On, S.T.U.N. Runner, Galaga, Space Duel.
Lilwolf
« Reply #3 on: July 07, 2005, 09:14:51 am »
wow at those prices... it might be worth buying another pot based joystick on ebay and hope for a better set.
alphasqorner
    • AlphasQorner
« Reply #4 on: July 07, 2005, 10:20:32 am »
hey lilwolf, what kind of re-wiring did you have to do?  did you have to swap the "axis" and +5 connections? (or swap ground with axis, or any combo of the three)
« Last Edit: July 07, 2005, 11:00:30 am by alphasqorner »
Ken Layton
  • Guru
  • Technician
« Reply #5 on: July 07, 2005, 11:22:56 am »
There are several well-known volume control/potentiometer cleaning/lubricating sprays on the market. The one I like to use is "Nu-Trol Control Cleaner" (with lubricant). It is made by MG Chemicals and is catalog number 401B-140g (barcode 779008401149). They can be contacted at 1-800-201-8822 or www.mgchemicals.com
To use, just stick the little red nozzle that comes with the can into the cleaning hole in the pot/volume control and give it a quick tap of a spray. Now turn the control shaft all the way through it's full range back-and-forth several times. Control should now be clean and noise free.
« Reply #6 on: July 07, 2005, 12:07:02 pm »
I found my AKI works best with 5k arcade pots, better than 100k gameport-style pots, fwiw.  It could be just co-incidence, I'm not sure...
