Author Topic: Coin locks size?  (Read 1207 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
Coin locks size?
« on: July 06, 2005, 03:18:20 am »
Is there a standard size of lock for arcade coin doors? Circa 1985.  I drilled mine to gain access to the insides.
SirPeale
  • Green Mountain Man
Re: Coin locks size?
« Reply #1 on: July 06, 2005, 06:32:45 am »
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
« Reply #2 on: July 06, 2005, 08:43:32 am »
Unless it's using a round key, there's no need to drill:
http://home.howstuffworks.com/lock-picking.htm
7/8th as Peale says is the usual size for metal doors, but I've had to do some tweaking by bending the metal plate on the back of the lock to get it tight or loose enough.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 06, 2005, 09:56:01 am »
7/8" is standard length, but that vintage might have had a 5/8" long. Everything nowadays is standardized at 7/8".
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« Reply #4 on: July 06, 2005, 09:55:51 pm »
I made the mistake of buying 5/8" locks for my door, because I thought that the measurements were in terms of the width of the lock hole, but then when I installed one the shaft was too short to lock. So I had to go and order the 7/8" locks instead. I think that 7/8" is more or less the "industry standard" for coin doors.
ericball
  • Last login:January 30, 2024, 03:07:18 pm
« Reply #5 on: July 08, 2005, 03:33:31 pm »
Measure twice, buy once!
Take a bolt and thread a nut onto it almost all the way.  place the bolt through the hole so the bottom of the head is resting against the outside of the lock hole.  Take something flat and place it against the the spot where the cam would hit.  Now spin the nut until it hits the "cam".  Take out the bolt and measure from the bottom of the head to the bottom of the nut.
Note: you can buy offset cams (typically 1/4") to change a 5/8" lock into a 7/8" lock, or vice-versa.
The coin door from my Tempest is 5/8".
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25%
2004 Tempest cabinet & CP > 75%
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional
ericball
« Reply #6 on: July 12, 2005, 11:14:00 am »
tkuper05
« Reply #7 on: July 12, 2005, 07:02:23 pm »
So these locks only come in different length's, not width's?
ericball
« Reply #8 on: July 13, 2005, 11:44:32 am »
3/4" diameter (not the flat, which is 0.635") is the most common, but there are larger & smaller locks available.
http://www.eastloc.com/camlock1.htm (they give both mm and decimal inch measurements)
