Author Topic: Tetris: 4-way or 8?  (Read 1768 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Tetris: 4-way or 8?
« on: July 05, 2005, 09:37:10 pm »
Looking over KLOV they keep listing Tetris as using a 3-way (which would be a 4-way that you just never push up) and I was wondering if this is correct. Would you not want to move a piece down diagonally?
NO MORE!!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: Tetris: 4-way or 8?
« Reply #1 on: July 05, 2005, 09:56:44 pm »
It is definitely a four way.  By the way, Tetris Grand Master is the best ever!
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: July 06, 2005, 01:53:47 am »
BTW, moon shuttle is a wierd 5-way.
jcroach
  • Last login:March 01, 2012, 09:36:56 am
« Reply #3 on: July 06, 2005, 09:39:35 am »
Not to hi-jack the thread, but can you describe this a little further?
walls83
  • beer is good
« Reply #4 on: July 06, 2005, 12:23:12 pm »
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #5 on: July 06, 2005, 01:43:57 pm »
I'm curious about this too. The manual mentions a 5-way joystick, but the joystick assembly looks like an 8 way.
http://www.arcadedocs.com/vidmanuals/M/MoonShuttle.pdf
2600
« Reply #6 on: July 06, 2005, 01:54:25 pm »
Looks like, you were on the right track JoyMonkey.  Look at the schematic, it only connects up,down, and right.  Therefore it only can see 5 directions.  The joystick itself seems to be a normal 8-way.  I don't know if they actually connected the 4th microswitch or not and there doesn't appear to be any kind of restrictor.
Edit: Something possibly to make note of in Controls.Dat
« Last Edit: July 06, 2005, 01:56:21 pm by 2600 »
JoyMonkey
    • JoyMonkey.com
« Reply #7 on: July 06, 2005, 02:04:03 pm »
Back to the topic; the Tetris manual says that the conversion kit comes with two 4-way sticks, but the Jamma table says that up is not connected (so it's a 3-way):
http://www.arcadedocs.com/vidmanuals/T/tetris-kit-manual.pdf
Q*Bert_OP
  • Oh yes, we did!
« Reply #8 on: July 06, 2005, 03:01:52 pm »
up, down, forward(right), up/right, down/right
and it does look just like an 8-way stick, except it has a restrictor plate only allowing movement in 5 directions, and only 3 microswitches
« Last Edit: July 06, 2005, 03:04:24 pm by qbert247 »
