Author Topic: Any way to get 5v output to drive a relay  (Read 1017 times)
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« on: July 02, 2005, 12:44:00 am »
I am using a 25" Sony TV in the cab and so far I am very happy with the results.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
Chris
    • Chris's MAME Cabinet
Re: Any way to get 5v output to drive a relay
« Reply #1 on: July 02, 2005, 09:20:58 am »
Parallel port's probably your best bet... should be a ton of articles around triggering a switch through the parallel port...
Start at http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm .
--Chris
--Chris
toolaa
« Reply #2 on: July 02, 2005, 10:22:59 am »
Thanks, this looks like it will work.  Great site by the way, lots of cool stuff that I'm sure I'll need next year when my son has to do a science fair project.
fiscap
  • Last login:September 10, 2023, 08:10:16 pm
  • I dare ye enter... the dungeons of daggorath!!!
    • BYOAC blog
« Reply #3 on: July 02, 2005, 11:50:35 am »
Also check out - http://www.epanorama.net/circuits/rspower.html
Be very careful interfacing any type of home-brew electronics with your computer - you might cause some irreparable damage to the port or even your motherboard. I would suggest using some sort of solid-state driver circuit to trigger the relay since connecting the coil directly to your PC could potentially create a situation of abnormally high current draw or inductive loading. The triggering of the coil would also create noise on the circuit which might have adverse affects on your serial/parallel ports.
rdagger
« Reply #4 on: July 02, 2005, 09:40:15 pm »
richms
  • Last login:September 03, 2022, 02:33:54 am
  • s92a sucks
    • richms.com
« Reply #5 on: July 02, 2005, 11:25:39 pm »
Perhaps rather then a relay, you could get one of the USB to IR transmitters that are used a lot in home automation, and just send the codes for video 1 or video 2 at the apropriate time? That would also avoid the tv getting out of sync with what the computer thinks the TV is set on if you are only working with the 1 button on the orig remote.
toolaa
« Reply #6 on: July 03, 2005, 01:45:57 am »
OK, Now were cookin' with GAS....
I think USB-UIRT with Girder software is going to do the trick...
I have to ponder this a bit more, for $79 I just want to make sure it's really going to do exactly what I need.
Anyone have any experience using Girder?
