Author Topic: AdvanceCD is bloody amazing!!!  (Read 2997 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: July 01, 2005, 03:34:57 pm »
i wasnt expecting it to work but i gave it a go.  just burn to cd and boot the computer with the cd in the drive. works on arcade monitor, has sound and loads super quick (even on a 500MHz PC)
absolute quality ;D
Grasshopper
  • Last login:November 08, 2023, 07:20:31 am
Re: AdvanceCD is bloody amazing!!!
« Reply #1 on: July 01, 2005, 03:44:11 pm »
I tried it recently and was also very impressed. You can also install it onto a USB pen drive which is cool.
Unfortunately, I cannot get it to work with my new graphics card (Geforce 6600GT). I suspect this could be solved by replacing the kernel with a more up to date version but it's tricky to do this unless you also have a full Linux distro on your hard drive.
eggedd2k
« Reply #2 on: July 01, 2005, 05:05:29 pm »
is that card not one of the supported ones?
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #3 on: July 01, 2005, 06:04:25 pm »
My Intel chipset is also not supported for advanceCD :( but i know it is
great.Have you guys tried to enhance AdvanceCD,i mean to put more
games in the Roms folder before making an ISO amage.I did not try it
my self but once i get a new graphics card i will move towards Linux advmame and advmenu.
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #4 on: July 01, 2005, 06:27:31 pm »
I've tried this but failed, I think my mobo is the culprit :(
I currently don' t have a computer in my arcade cabinet  >:(  I have my dual celeron system BUT I don't have a hard drive for it.  I've been tempted to create an advancecd for it that loads roms from a network share.
Grasshopper
« Reply #5 on: July 01, 2005, 07:05:00 pm »
Have you tried updating your BIOS?
When I first got my motherboard it didn't provide the facility to boot from a USB device. But when I updated the BIOS this facility appeared even though it is not documented on the manufacturer's website.
SirPoonga
  • Puck'em Up
« Reply #6 on: July 01, 2005, 11:44:33 pm »
I will have to try it on my dual celeraon system sometime.  This computer does have boot devices for USB-FDD, CDROM, and ZIP.  I couldn;t get either of them to work.  It might be the usb drive too.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #7 on: July 02, 2005, 12:32:50 am »
Does your CD-rom spin continually while playing games or do the games get loaded into RAM?  I'm just wondering cuz my CD-Rom is loud.
-- Chad Tower
SirPoonga
  • Puck'em Up
« Reply #8 on: July 02, 2005, 01:20:58 am »
mame should load roms into memory.  hard drive images it will run off disk.
eggedd2k
« Reply #9 on: July 02, 2005, 04:56:58 am »
once the game's loaded it's silent.
Franco
« Reply #10 on: July 03, 2005, 07:08:39 am »
Thanks for the tip! I never knew about this prog.
MAME at work, loving that idea!
eggedd2k
« Reply #11 on: July 03, 2005, 11:03:27 am »
advancemame is a modded version of mame.  runs straight off the cd. best of all it's dead easy to configure.
SirPoonga
  • Puck'em Up
« Reply #12 on: July 04, 2005, 04:34:43 pm »
It's probably my usb stick.  I setup it both as not USB-ZIp compatible and as USB-ZIP compatible when running the makeusb bat file.  But I couldn;t get it to boot on this computer.
But it needs to be able to boot on whatever I put in my arcade.  I think I will resurect my dual celeron system again.  I want to do the usb stick thing because it would be easy to add games, and it is rewritable so I can switch settings easily.  That way if I want to setup samba and a network share I don't have to host the roms on that stick.
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #13 on: July 05, 2005, 01:22:23 pm »
I tried 3 computers (with 2 monitors each) this weekend until I found a combination that worked. I'm generally disappointed by the limited video card and monitor support. But I was pleased with the setup and "installation" once it worked. But I can't imagine suggesting this to anyone that doesn't know how to grep xrc files.
The first computer had an incompatible video card, and possible an incompatible LCD display; but switching to a CRT didn't allow advanceCD to run. The second computer froze up whenever MAME launched. The third computer had an LCD display that was incompatible so I switched it out for an old 15 inch CRT monitor.
It seems odd that AdvanceCD doesn't work on TVs and Arcade Monitors when it's based on AdvanceMAME which specializes in working on TVs and Arcade Monitors. *shrug*
I do like the effort and I hope to expand on it a bit, for personal use. :)
Joseph Elwell.
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
« Reply #14 on: November 30, 2005, 03:13:02 pm »
Just found this prog, it's sweet!  ran perfectly right off the vanilla install.
Before I burned the CD I copied a bunch of roms into the roms folder and viola, they showed up on the burned CD just fine.  I still need to copy the snapshots/movies/screenshots files for the full effect.
I wonder how hard it would be to get the screen rotated?  I'll check into that, also.  But very impressed so far.
starcrudph
  • Last login:April 04, 2006, 05:43:30 am
« Reply #15 on: December 01, 2005, 08:06:53 pm »
i tried modifiying the latest build, for the life of me i cant get the roms to run. im using winxp ntfs. any help?
note: i used to have no problems whatsoever with other versions.
unix4hire
    • My Business
« Reply #16 on: December 02, 2005, 01:27:46 am »
where did you put the roms?  After you unzip the downloaded advcd pentium file put the roms in the folder:
arcade\rom
and then execute the createimage file (or whatever it's called?).  It creates the .iso file which you then burn to CD.  The roms are built into the iso.
elvis
  • Last login:April 13, 2023, 05:31:03 pm
  • penguin poker
    • StickFreaks
« Reply #17 on: December 02, 2005, 07:45:54 am »
AFAIK AdvanceCD uses Linux's FBDev drivers built into the kernel, which doesn't support TV-out.  For that you need drivers which support TV out.  Currently AdvanceMAME supports FBDev (no TV-out support), SVGALib (no TV-out support), and SDL via X (TV-out support, dependant on the driver you use).  Also it's worth noting that the PAL and NTSC TV settings in the advcfg utility are for people who desire to build their own RGB hacks to output direct from the analogue DSUB15 on most video cards straight into RGB input on a TV (ie: SCART, etc).
Arcade monitor support is there, but you have to change the config file manually.  This step was done on purpose to prevent not so bright people from destroying their PC monitors.  Consider it a litmus test: if you have to ask HOW to add support for real arcade hardware, then you probably shouldn't be doing it.
delta88
  • Last login:April 22, 2022, 09:53:16 pm
  • This place is still here?
« Reply #18 on: December 02, 2005, 09:46:29 pm »
Bah! litmus test.. I'd say that would bethe case 50% of the time. I have modified the config for this by adding my own .rc file to whatever \dir that it was sappose to go in but it is very tough to get the arcade monitors to werk with it.
do we have any advance Cd gurus in this forum?
thx
 d88
starcrudph
« Reply #19 on: December 03, 2005, 10:20:05 am »
yeah i have alot of questions about advcd, i want 2 player,6 -button support. i know how to edit the .rcs, like picoing in linux and make extract make app etc. but when i get the app.img file i copy it to a windows box and put it in the root folder. lately i cant get it to work anymore, im pretty sure i got the roms in the rom folder. im using an xp ntfs setup, will this affect the cd image created?
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
« Reply #20 on: January 11, 2006, 11:56:47 pm »
Decided after a long LONG haitus that I would finally start working on my cocktail cabinet.  Bought a Micro-ATX board based on a Centaur/Cyrix/VIA/Whatever-They-Are-Called-Now CPU.  Looking at Advance CD as a potentially easy way to install and boot from a CF card ala JoyMonkey and his DOS install (rather stick with Linux then DOS, but if this doesn't work then DOS will be next).
Anyone install Advance CD to a hard drive or CompactFlash with success?  Any tips?  Anyone use it successfully with an ITX mobo?
Harpal
  • Last login:April 02, 2006, 12:02:22 pm
  • I'VE STARTED BUILDING MY FIRST MINI ARCADE!!!
    • 3D-ARCADE at MAMEWORLD
« Reply #21 on: January 12, 2006, 07:14:29 am »
i use the same set up and have had no problem making the cd or play a boot usb stick, both of them work great.....
perfect to take college with so anytime you want to play all you need to do is  reboot ur laptop.....
i have tried making the HD bootup with advance cd, but kept getting problems so going to try doing the whole progress through msdos and will see if it work.....
if i manage to do it i will let you all know the best way of doing it????
HAPPY NEW YEAR!!!!!
---------2006-----------
