Main > Main Forum
Overclocking
krick:
--- Quote from: USSEnterprise on July 01, 2005, 05:34:04 am ---My MAME PC is an IBM 3000GL with a 300MHz Pentium II with 512K cache and a
USSEnterprise:
System Info
Model : Trigem Dublin
Chassis Type : 1X
Operating System : Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
Processor
Number Of Processors : 1
Type : Intel Pentium 4 1600 MHz
Processors Bus Speed : 400 MHz
Motherboard
Manufacturer : TriGem Computer, Inc.
Model : Dublin Rev. None
CPU Slot/Socket Type : mPGA-478
Chipset Vendor : Intel i845 Rev. 4
Bios Manufacturer : Phoenix Technologies LTD
Bios Version : 6.00
Graphics
Model : nVidia AGP NVIDIA GeForce FX 5500
AGP Speed : 4x
Monitor : Plug and Play Monitor
Storage
Hard Drive 1 : Maxtor 2F040L0
Hard Drive 2 : SanDisk Cruzer Mini
Memory
Total RAM Installed : 384 MB
Type : SDRAM DIMM PC133
Used RAM Slots: 2 of 3
Peripherals
USB Version : 1.1
USSEnterprise:
I'm not sure it will run on the IBM, because at the moment, it is running Debian Linux
Tiger-Heli:
--- Quote from: krick on July 04, 2005, 10:45:09 pm ---I've overclocked (or attempted to overclock) every computer I've ever owned. I have yet to damage anything.
I imagine, that if you had a CPU with really poor cooling that you *might* be able to damage it by overclocking, especially if you increase the core voltages WAY over the specs while trying to do it.
I have never heard of anyone damaging a motherboard while attempting to overclock.
Depends - I had a Pentium 200 that I overclocked to 225 Mhz by changing the FSB from 66 to 75 IIRC, but the mobo didn't have the proper dividers for the PCI bus. Worked fine with my WD (I think) HD. Then I upgraded to a Maxtor HD and it took six hours to load Windows. I called Maxtor CS and they said that could cause the problems and would also void the warranty. Set it back to 200 and used it with no problems for a couple more years.
YMMV.
krick:
--- Quote from: USSEnterprise on July 05, 2005, 04:40:34 am ---System Info
Chassis Type : 1X
Processor
Motherboard
Bios Version : 6.00
Memory
Well, you have a Trigem Dublin motherboard. According to this page...
http://www.emachineupgraders.info/dir1/motherboards/socket478/dublin.shtml
...it *should* support Northwood processors. I think that it only supports ones with a 400MHz front side bus and they top out at 2.8GHz. Here's a search on the Intel page...
http://processorfinder.intel.com/scripts/list.asp?ProcFam=483&NoNav=NO&CorSpd=ALL&SysBusSpd=5095&MfgTech=ALL&step=ALL&cache=5887&PkgType=ALL&btnFOS=Filter+on+selections
Here's a little more about the Trigem Dublin, including BIOS upgrades...
http://www.elhvb.com/mboards/TriGem/
From what I'm finding on the net, overclocking isn't really an option with that motherboard. Unless you can find a setting in the BIOS that allows you to increase the CPU front side bus, I don't think you can overclock it. If you do find that option, you will probably need to change the clock divider on your memory so that it doesn't get overclocked and unstable.
