Author Topic: MDF paint process?  (Read 1536 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
MDF paint process?
« on: June 29, 2005, 01:33:39 am »
Is there anything wrong with this paint process?
I will be painting 5/8 MDF.
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
Re: MDF paint process?
« Reply #1 on: June 29, 2005, 01:55:31 am »
Sounds good. Obviously, make sure the paint and primer are compatible, but other than that, no worries.
-- Chris
Underway: Joey's Arcade
xonix_digital
  • Last login:February 20, 2016, 04:36:05 pm
  • I am the Milky-Way Commander!!!
« Reply #2 on: June 29, 2005, 02:08:49 am »
I thought mixing oil and water based paints was bad...   :(
I really don't know though... That would be my first inclination.
-=XD=-
armax
  • Last login:July 12, 2017, 07:20:15 pm
  • Game Not Over
« Reply #3 on: June 29, 2005, 02:12:28 am »
I think you can do latex on oil primer but not oil-based paint on latex primer....not sure though.
Havok
  • Trade Count: (+17)
« Reply #4 on: June 29, 2005, 10:54:39 am »
You can apply latex over oil, but not the other way around. Latex needs to "breathe" and oil doesn't - it dries harder.  Oil takes much longer to dry, just make sure it is completely dry before sanding\applying the next coat.
tkuper05
« Reply #5 on: June 29, 2005, 04:20:13 pm »
So what about latex paint over my oil primer then?
krion
  • Last login:January 13, 2021, 01:18:20 pm
« Reply #6 on: June 29, 2005, 04:57:10 pm »
i used latex primer and latex paint which turned out brilliantly.  I used Zinser brand primer and a decent quality latex paint on top.  2 coats of primer and i think 4 coats of paint sanding between each, looks really good.  Oil makes life easy on MDF, but if you use a really good quality latex primer and put 2 coats, allowing each to dry properly, it should be fine.
tkuper05
« Reply #7 on: June 29, 2005, 05:42:43 pm »
I will definitely consider latex paint on latex primer.  I just don't want to use a water based primer.  Do you have any pics of your cabinet Krion?
armax
  • Game Not Over
« Reply #8 on: June 29, 2005, 05:43:19 pm »
tkuper05
« Reply #9 on: June 29, 2005, 05:48:18 pm »
I'm very ignorant with types of paint.  So, latex is water-based?  If so, I'm going to use oil-based primer and latex paint.  If latex primer isn't water-based then I'm gonna use latex on latex.
armax
  • Game Not Over
« Reply #10 on: June 29, 2005, 06:07:38 pm »
tkuper05
« Reply #11 on: June 29, 2005, 06:55:22 pm »
I've been reading some about using a sealer to make the end pieces look consistent to the flat, broad pieces due to the fact that the end pieces soak up a ton of primer/paint.  Anyone else do this?  I think I'm gonna go with latex primer/latex paint.  I don't care how long it takes to dry.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #12 on: June 29, 2005, 07:16:43 pm »
All the edges I ended up with were covered with t-molding. This was the two sides and the edges of the CP.
