Poll
What material did you use?
Oak
2 (6.7%)
Birch
6 (20%)
MDF
18 (60%)
Other
4 (13.3%)
Total Members Voted: 30
Author Topic: Cabinet construction real wood vs. MDF  (Read 2664 times)
Havok
  • Trade Count: (+17)
« on: June 24, 2005, 12:01:46 pm »
I'm starting to build a cab, and I am leaning towards the real stuff. I have some MDF cabinets\furniture that doesn't make it sometimes when moved.
Just wondering what is out there. I'm sure MDF is the prevalent choice, but just interested in what the rest of the community is doing...
*edit* - I am definitely referring to veneered plywood...
« Last Edit: June 24, 2005, 12:11:14 pm by Havok »
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
Re: Cabinet contruction real wood vs. MDF
« Reply #1 on: June 24, 2005, 12:06:18 pm »
I assume you are talking about oak- or birch-veneered plywood, rather than "the real stuff" (solid hardwood).
My cabinet (currently under construction) is MDF for the main panels, 3/4" birch plywood for the base, and hardwood (red oak) for selected parts (mainly the monitor frame/support).
-- Chris
Underway: Joey's Arcade
AlanS17
    • AlanS17
« Reply #2 on: June 24, 2005, 12:08:50 pm »
MDF if heavier and more prone to water damage. However, it's easier to cut, cheaper, and requires less prep work for finishing. It comes down to personal preference.
There's no reason NOT to go with MDF for the control panel, but you'll have a lighter, sturdier machine if you use plywood for the sides.
siropa
  • Last login:November 12, 2020, 12:08:56 pm
Re: Cabinet construction real wood vs. MDF
« Reply #3 on: June 24, 2005, 01:06:46 pm »
I went with birch plywood for cab #2 main because I hate the dust from MDF. My woodshop is in my basement and the idea of routing on MDF isn't too appealing. Given all the other costs I had buying all the parts, a few bucks on the sheet goods was minor.
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
« Reply #4 on: June 24, 2005, 01:45:52 pm »
I guess the $20,000 question is what are you trying to accomplish?
If you want to make a standard arcade looking cabinet and you're going to paint it and put artwork on the sides and just don't want it to go into solution if it's feet get wet, then I'd recomend A/C grade pine plywood.
If, on the other hand, you want it to look like real live honest to God furniture, well, pretty much any of the woods you listed would do the trick.
I'm going to put some cards on the table here and reveal my weird little plans....
I am currently restoring an arts and crafts house that has suffered many years of neglect.  When I'm done the machine that I'm currently building in the hull of an old gutted Berzerk cab will stick out like a sore thumb.  What I want to build next (there's a phrase to make the wife shudder) is something that looks like a colaberation between Nolan Bushnell and the Greene brothers.  That one will probably made of quarter sawn white oak and ebony with very little plywood involved.
(For those of you wondering, there's a good Greene and Greene inspired desk here: http://www.furnituremaker.com/)
Avery
Havok
« Reply #5 on: June 24, 2005, 03:50:38 pm »
That's the thing: I have a small office\computer room where this thing just won't fit. So, since I don't have a basement (sigh...) It's going in the garage. So, moisture is definitely an issue. I get the feeling that plywood will also be stronger: I've ripped screws out of MDF panels when moving before. It seems to me that MDF is basically cardboard on steroids.
CJK
« Reply #6 on: June 24, 2005, 09:46:19 pm »
That's because most people don't use the right kind of screws with MDF. MDF doesn't hold the typical fasteners you find in Home Depot particularly well, so a fastener designed for MDF is advisable. Here's an example:
http://www.mcfeelys.com/multiple.asp?productID=7050-CSP
If you can do without mechanical fasteners, so much the better. Dowels or biscuits and glue will make a joint which is stronger than plain screws anyway.
That said, there is a lot to be said for plywood over MDF as a cabinet material. If you don't have much woodworking experience or haven't worked with MDF much, you'll find plywood much friendlier (and not just because of the dust, though as mentioned above, that is a big issue with MDF!). However, I'd use MDF on the control panel because it machines much more easily than plywood, especially for things like routing out recesses on the CP.
-- Chris
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #7 on: June 25, 2005, 10:09:45 am »
I'm getting visions of a Frank Lloyd Wright-ish cabinet.  ;)
What games would look right being played on it? Maybe Shanghai. Or Tetris.
Be cool with mother of pearl inlayed and a stained-glass marquee.
- pmc
Avery
« Reply #8 on: June 28, 2005, 09:36:44 am »
I don't know that any games are REALLY going to look right on it, but that paradox is part of the fun as far as I' concerened.
I'd thought about the stained glass marquee, but not the inlay.  Thanks for the idea.
Avery
