Main > Main Forum
control interface for pac man
Pages: << < (3/3)
quarterback:
--- Quote from: paigeoliver on June 21, 2005, 12:46:02 am ---Why 4 buttons?
You must really like Mouse Trap, because it is the only 4-way vertical game that uses more than 2 buttons.
Mouse trap uses four buttons?
Kev-in DFW:
The KeyWiz Eco is THE way to go.  I just installed a KeyWiz Max and really like it a lot.  I highly recommend Randy's goods.  Not that I have used a bunch, but what I have used I like.
Good Luck
Kev~
dogg0:
It would probably make more sense to go with the uncluttered 2 button setup rather than installing 2 extra buttons for a game you are never going to play. Even if you do want to play it, you still can simply by mapping the start buttons as buttons 3 and 4 (buttons 2 through 4 hardly ever get used in Mouse Trap).
I really meant, just 2 buttons on the cp, and then 1 for start and 1 for coin. I may even just use the "shazaaam" function for coin. Thanks for the posts. Has anyone used the kb16 though? I'd be interested to know the best way to install them...
Tiger-Heli:
--- Quote from: dogg0 on June 21, 2005, 10:24:09 am ---I really meant, just 2 buttons on the cp, and then 1 for start and 1 for coin. I may even just use the "shazaaam" function for coin. Thanks for the posts. Has anyone used the kb16 though? I'd be interested to know the best way to install them...
Why???
I've tested the KB16, as has RetroBlast, it can work (for your setup), but you would want to wire Button 2 to Button 3 on the KB16, Wire 1P Start and Coin 1 as indicated, Wire Escape to Button 5 and Pause to Button 7 (if you wanted these) and then re-program the unit to match.
My question is why you would want to go through this much hassle when a KeyWiz Eco is less money and supports 32 inputs and 20 shifted inputs, software reprogramming, etc, without all of this hassle?
My KB16 test is here - http://forum.arcadecontrols.com/index.php/topic,37906.0.html
dogg0:
I guess I wouldn't! I will now be ordering the keywiz eco  :laugh:
Pages: << < (3/3)
Go to full version
