Main > Main Forum
How the heck to I get this cab on its back?
M3talhead:
Lighter fluid - $5.00
Match - $0.50
___________________________
1. Soak cab with lighter fluid.
2. Light match.
3. Run
4. Douse with water (optional*)
5. Carry smoldering remains to new location.
CheffoJeffo:
You shouldn't have too much trouble, particularly with a couple of helpers.
I wouldn't remove the monitor, but I would check that it is securely mounted and that nothing else is floating around too loose inside.
Good luck.
Cheers.
dag2000:
--- Quote from: ChadTower on June 20, 2005, 03:10:57 pm ---A healthy man of that size should have no problem doing that alone.
AlanS17:
--- Quote from: dag2000 on June 20, 2005, 06:28:16 pm ---
