Author Topic: PLEASE HELP FIRE HAZARD QUESTION!  (Read 899 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: June 20, 2005, 10:57:56 am »
Hi. I was working on my x arcade unit putting it in a custom case. I forgot to drill the hole for the programming button on the back. So I did it after everything was together. ( ya I know it was a stupid thing to do but I was The bit went through and tangled around the white wire that connects the player 1 and 2 buttons. It was not torn through but the plastic stripped off down to the bare wire in a 2-inch spot. I used electrical tape and sealed the exposed wire. Every thing works fine now. My question is will this cause a fire hazard. Im guessing it wouldn
ray_slup
  • Last login:July 11, 2020, 11:12:38 am
Re: PLEASE HELP FIRE HAZARD QUESTION!
« Reply #1 on: June 20, 2005, 11:07:41 am »
I doubt it , you put electrical tape around it. That's what electrical tape is for.
If it bugs you, change the wire. I don't think the wire would get hot enough. I think only 5v go through the button wires. Plus if its on the button there wired for normally open so no electricity is going through them unless the button pressed
« Last Edit: June 20, 2005, 11:20:12 am by ray_slup »
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: June 20, 2005, 11:09:06 am »
It should not cause a fire hazzard, I would put shrink tubing around the wire instead of electrical tape.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #3 on: June 20, 2005, 11:11:20 am »
So long as you have repaired and insulated the wires as good or better than they came out of the factory, you're fine. The important thing is to ensure you dont short anything out.
Signature tags are dumb.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: June 20, 2005, 11:18:33 am »
Are we talking about a wire that goes to buttons? The voltage is too low to be a real fire hazard. So your taping it up is good enough.
NO MORE!!
ray_slup
« Reply #5 on: June 20, 2005, 11:22:14 am »
you posted is I was re editing to say the same thing :)
PoDunkMoFo
  • Last login:January 25, 2024, 07:27:17 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #6 on: June 20, 2005, 07:43:53 pm »
Ray's correct.
The only hazard would be sending the wrong button press or sending an unattended button press.
Of course there is the explosion hazzard :)
rlemmon
« Reply #7 on: June 21, 2005, 07:40:36 am »
tHANKS FOR THE INFO  :)
cbmeeks
  • Last login:July 01, 2006, 09:29:58 pm
  • Metroid Classic
    • Metroid Classic
« Reply #8 on: June 21, 2005, 10:28:29 am »
Anything that is flamable is a fire hazard...lol
Seriously, I would rip it out and redo it.  Not because it is dangerous, but because it would aggrivate the hell out of me knowing it was like that...but that's just me.   ::)
RETRO COMPUTERS!
A NEW place to chat about retro computers!
RETRO
METROID
Metroid Classic
