Author Topic: What size T-molding?  (Read 1318 times)
nickbuol
  • Last login:July 20, 2023, 03:27:15 pm
  • 2nd Time Around
« on: June 19, 2005, 03:21:19 pm »
I am looking at 5/8 with laminate on one side and "backerboard" on the other.  These are to me professionally applied and cut on a CNC machine at a local millworks.  I've never seen backerboard, so I am not sure what to do.
T-Molding comes, obviously, in 5/8" and 3/4" widths.  I was thinking 3/4", but was hoping for some confirmation.
I should also use a 1/6" slot cutter, right?
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
Re: What size T-molding?
« Reply #1 on: June 19, 2005, 03:40:08 pm »
I don't know about the thickness of the backerboard, but for the slot you want a 1/16" slot cutter.
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« Reply #2 on: June 20, 2005, 09:53:08 am »
I used 3/4 MDF and formica on one side. I used 13/16 t-molding, black; pretty much all you can get in that size, and that size was perfect. 1/16 router bit cut, make sure its in the middle taking into account the formica on the one side, so on the mdf it will be slightly off center...
The Way Back Machine - http://www.taborious.com
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« Reply #3 on: August 17, 2006, 06:10:16 pm »
Hmmm, 3/4" would be 12/16 and you used 13/16 and it was perfect. That gives me pause cause I have 1/16" laminate on one side and nothing on the other on 5/8" MDF and I wondered what size. I have 5/8" in hand, but I wonder if I should go 3/4"
nickbuol
  • 2nd Time Around
« Reply #4 on: August 17, 2006, 06:39:59 pm »
5/8" = 10/16"
10/16" + 1/16" = 11/16"
3/4" = 12/16"
11/16" does not = 12/16"
Use 11/16" T-Molding...
releasedtruth
  • Projected Nexus
« Reply #5 on: August 17, 2006, 09:12:28 pm »
I understand the ideal size is 11/16, but my hope is that 3/4 will work as well. It's only because the black-chrome-black t-molding I have looks so much cooler in 3/4"  The chrome strip is thicker. I have plenty of 5/8" I'm just deciding whether I want to go bigger then exacto off.
nickbuol
  • 2nd Time Around
« Reply #6 on: August 17, 2006, 09:37:03 pm »
If you get your t-molding exactly on center, then you are talking only 1/32" 'extra' on each 'side' of where you are putting the t-molding.  I wouldn't try to exacto it off.  It will be difficult to cut exactly perfect, and that would be noticable in chrome.  So a little 1/23" overhang, so to speak, probably isn't going to be noticed by anyone but yourself.
