Main > Main Forum
How wide is your cabinet?
missioncontrol:
22 or 24 inches I'll have to measure it later ........
joshbr7257:
ok ive read all of your guys rewsponses, thanks for those, but im going to ask what you guys think. my control panel top is 34 inches wide and the bottom box is 30 inches wide. its a 2 person cp, and ill be using a 20inch tv, so should i make my cab like 24inches wide? or is that to much empty space?
BarontheFirst:
Well I matched the bottom of my cp to the width of my cab. Mine is 30" but I also used a 27" screen. Right now it is a two player CP but one day I will build a 4 player. Hope this helps you out!
Ghoward:
28.5" wide
Gary
rhoelsch:
Cp is 34" wide, cab minus cp is 27"....can detach cp and fit thru my basement door....24" TV...
