Author Topic: How wide is your cabinet?  (Read 3523 times)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
« on: June 18, 2005, 03:05:36 am »
i am making a cabinet soonand i just wanted to know how wide otherpeoples were at first i was planning on making mine 30 inches wide but than relized thats way to wide. so please tell me how wide your are.
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
rescue161
  • Last login:January 29, 2022, 04:11:18 pm
  • I built my own Cabaret machine!
Re: How wide is your cabinet?
« Reply #1 on: June 18, 2005, 03:26:23 am »
20 3/4"
It's a cabaret cabinet (one player).
"Censorship reflects a society's lack of confidence in itself." - Supreme Court Justice Potter Stewart
joshbr7257
« Reply #2 on: June 18, 2005, 03:28:28 am »
oh mine is going to be 2 players
AlanS17
    • AlanS17
« Reply #3 on: June 18, 2005, 03:31:25 am »
What size of monitor do you plan on putting in there? That makes a lot of difference. My 27" wouldn't fit in anything less than about a 29" inch inner width.
joshbr7257
« Reply #4 on: June 18, 2005, 03:36:14 am »
for now i will be using a 17in cp screen but i want to make it big enough for like a 21in tv
AlanS17
    • AlanS17
« Reply #5 on: June 18, 2005, 03:43:13 am »
Well 20 3/4" is just about standard for cabinets fitting 19" monitors. Depending on how bulky your TV is, it ought to fit in that space constraint.
If you're using a smaller monitor like that, though, I'd recommend not making the cab too wide. It'll only make your monitor look smaller. There are plenty of sets of plans online, though, and you can use existing machines as a basis for comparison. One of them is bound to suit your needs.
joshbr7257
« Reply #6 on: June 18, 2005, 03:48:48 am »
the reason i was planning (at first) making my cabint 30 in wide is cause my control panel is 30in wide, if my cabinet is smaller how do i mount it? how will i keep it from moving? i want to keep it removable so in the future i can make a 4 person cp.
AlanS17
    • AlanS17
« Reply #7 on: June 18, 2005, 03:53:51 am »
Look up a picture of a TMNT or an NBA Jam. Both use a wide control panel that sits on a sort of a shelf yet it's still built-in. It's pretty much how all newer 4player games are built.
armax
  • Last login:July 12, 2017, 07:20:15 pm
  • Game Not Over
« Reply #8 on: June 18, 2005, 06:47:58 am »
Toshiba 27" TVs measure 26" in width.  does yours have side speakers?
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
« Reply #9 on: June 18, 2005, 10:11:54 am »
Mine is 30" outside and 28 1/2" inside this is fine for my 27" with bottom speakers. Also a large enough screen for a 4 player cp once I get around to it. Now I did see you plan on going 21". Is this temp or perm. In other words are you using what you already have or are you buying this new 21"? If you go with a 4 player CP you may find a 21" to be a bit small. A 21" is fine for a 2 player cab. I bring this up about the 4 player because I have 3 kids and I know it will see alot of play time with there friends and my family. My screen size changed 3 times as construction took place. :) So basically in all this what I am trying to say is your CP will tell you your screen size in the end! I hope this helps good luck!
AlanS17
    • AlanS17
« Reply #10 on: June 18, 2005, 11:21:43 am »
joshbr7257
« Reply #11 on: June 18, 2005, 06:42:19 pm »
thanks for all the info, im i actually have a spare 21in tv in the garage im going to use, this is my first cab and i dont want to go out and buy a tv just for it when i know im going to make mistakes and its being run by a p2 computer, i will wait till my 2nd project and then ill have expierience so ill make it how i want itpust a better computer in it and a bigger tv.
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
« Reply #12 on: June 18, 2005, 07:34:16 pm »
NoOne=NBA=
« Reply #13 on: June 18, 2005, 07:55:15 pm »
I'm guessing you didn't decase it?
My 29" tube only measures 24-3/8 at the widest part of the mounting plates.
AlanS17
    • AlanS17
« Reply #14 on: June 18, 2005, 08:46:32 pm »
It's decased. It's just big. The 27" refers to the viewable area, not the size of the tube.
NoOne=NBA=
« Reply #15 on: June 18, 2005, 09:10:39 pm »
You must have some HUGE mounting rails for that thing.
Mine BARELY stick out at all.
The tube is only 23-3/4".
With a couple stop dado routs for the mounting rails, I could JAM it into a 24" wide cab.
Give me 25", and I'd be set.
AlanS17
    • AlanS17
« Reply #16 on: June 18, 2005, 09:22:52 pm »
I was wrong. I have a 29" OUTER width. That makes it a 27.5" inner width. Then subtract another 3" for the frame. That makes is 24.5".
dema
  • Last login:September 02, 2014, 03:05:34 am
« Reply #17 on: June 18, 2005, 09:38:59 pm »
I'm about 75% complete with the cabinet , and mine is 30" wide, but that's because I have a rotating control panel and want to have enough room for two large players to play comfortably.
joshbr7257
« Reply #18 on: June 18, 2005, 10:08:07 pm »
ummm... im still not sure how wide to make mine, whats the average?
is 24inches wide ok, if i use a 21 inch tv?
elvis
  • Last login:April 13, 2023, 05:31:03 pm
  • penguin poker
    • StickFreaks
« Reply #19 on: June 18, 2005, 10:09:47 pm »
600mm [23.62" for you imperial lot] internally (636 externally [25"], including the 2*18mm MDF walls).   Big enough for a 21" monitor, or 52cm TV with slim side speakers.  You could probably *JUST* squeeze a 27" arcade monitor in there too.
27" monitor on the diagonal = (27/5)*4 = 21.6" wide, or roughly 550mm, plus a bit extra for good luck.
Making the cabinet too big for the monitor is ugly in my opinion.  It makes the monitor look smaller than it really is.  Even small monitors look fine in cabinets that are scaled down evenly in all dimensions.
« Last Edit: June 18, 2005, 10:11:23 pm by elvis »
elvis
  • penguin poker
    • StickFreaks
« Reply #20 on: June 18, 2005, 10:12:10 pm »
Should be fine.  But buy the TV *FIRST* and measure it before buying/cutting wood. :)
AlanS17
    • AlanS17
« Reply #21 on: June 18, 2005, 10:14:15 pm »
That depends if the TV you use has speakers onto the sides or the bottom. If they're on the bottom you ought to be just fine. If they're on the sides, though, I'm not making any promises.
joshbr7257
« Reply #22 on: June 18, 2005, 10:15:10 pm »
there on bottom
flyguy1821
  • Last login:October 23, 2022, 11:06:19 pm
« Reply #23 on: June 19, 2005, 08:20:42 pm »
mine is 66 inches wide.   ;D  although it is a 2 player sitdown.
joshbr7257
« Reply #24 on: June 19, 2005, 08:22:55 pm »
what :o i cant even imagine it being that wide :o can you post a picture?
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #25 on: June 19, 2005, 09:02:33 pm »
Mine has an interior width of 27", to accommodate a 27" tv.
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
« Reply #26 on: June 19, 2005, 09:20:34 pm »
just make sure you can fit it through the door when you're finished (",)
cdbrown
  • Bowowow
« Reply #27 on: June 19, 2005, 10:14:39 pm »
Mine doesn't fit through a normal door.  Thankfully I have a larger sliding door out the back and it wasn't going into any of the small rooms.  If it had to go into a spare room then I think my cab would be much smaller.
flyguy1821
« Reply #28 on: July 17, 2005, 11:44:02 pm »
Josh this is a picture of the cab right now.  I have progressed a little since this was taken but vacation and meetings have slowed the progress quite a bit.  The width is just a little over 66 inches.  The two arms standing up are for the steering wheels so they can be lowered and raised out of the way.  (or that is the plan anyway)  I had to be very careful on design because of the weight and mobility.  When finished it will break down into 3 parts and will all fit through a regular door.  I am just going to make sure it isn't me moving it   ;)  Its no joke this is one big mama jama!  I haven't seen anyone build a 2 person yet so I am taking on the challenge.  If anyone has built one or knows of one please post.
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« Reply #29 on: July 17, 2005, 11:49:21 pm »
My cab is about 28" wide to accomodate the 24" TV inside.
Flyguy -
More info on your cab please!
« Last Edit: July 17, 2005, 11:58:49 pm by GameOver »
Bones
  • [Moderator]
« Reply #30 on: July 17, 2005, 11:53:25 pm »
Mine is 700mm + the width of the cabinet walls. That makes 736mm wide or 29 inches and is to suit a 27" screen.
Mr. Bubblehead
  • Last login:May 16, 2007, 08:49:19 am
  • I use soap.
« Reply #31 on: July 18, 2005, 12:30:34 am »
My cab is 22" wide, with a 19" computer monitor.
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #32 on: July 18, 2005, 05:35:27 am »
My cabinet is 26.5" wide, with the interior being 25" wide to accomodate a Wells-Gardner D9200.
-- Chris
Underway: Joey's Arcade
kickngas
  • Last login:April 19, 2017, 12:29:04 pm
  • "You get my Cheez Whiz boy"?
« Reply #33 on: July 18, 2005, 06:44:01 am »
27.5" exterior width, not including the CP of course....I am using a 27" TV as the monitor.  Just don't attach your CP (if it is wider) until the cabinet is in it's final resting place.
Stingray
« Reply #34 on: July 18, 2005, 10:56:27 am »
24 inch outside width iirc. Classic Midway style cab.
-S
« Reply #35 on: July 18, 2005, 11:07:36 am »
Mine's 64cm wide (~25.6").
Zeosstud
  • Last login:April 17, 2024, 03:12:48 pm
« Reply #36 on: July 18, 2005, 05:09:17 pm »
29" Wide outside edge to outside edge.  27.5" Inside edge to inside edge.  has a WG 9200 inside, no problems.
Rodney
kcdonahue
  • Last login:October 12, 2015, 05:54:21 pm
« Reply #37 on: July 18, 2005, 07:54:30 pm »
My Mame cab was a Sega MJ Moonwalker cab and measures 27.5 Inches with a 25 In monitor.  The original CP is 29.5 inches.
KC
flyguy1821
« Reply #38 on: July 19, 2005, 02:29:01 am »
Gameover, the idea of the post are to attach the steering wheels to the far end.  I have actually put the lowering mechanism on the arms.  It is highly sophisticated (screen door hinges).  In between those 2 boxes, on which my Supra seats will be fastened, will be a console.  The arms will lower into the console slot providing more lateral support.  This is actually the step I am currently on.  Problem is I want to paint, laminate, or somehow cover the ugly 4x4 post. I am afraid after a few uses up and down the arms will begin to chip.  Also I am not sure if the arms drop into a slot in the middle console if there will be enough lateral support if someone were to crank on the steering wheel.  Now the idea makes sense to me but it all in that big space in my head.  If anyone knows what the hell I am talking about shoot me some advice.  I will try to take some updated pictures to make more sense.
flyguy1821
« Reply #39 on: July 19, 2005, 02:46:24 am »
Here is a picture of the cab I mostly looked at to get an idea of design.
