Main > Main Forum
adding a button
SirPoonga:
Ok, how many buttons are currently on the cocktail? Why are you adding this one? Is it going to be a button that should fall in the realm of jamma?
mvarady:
One currently.I bought this cocktail table with all the pac mans,all the donkey kongs,galaga,dig dug,galaxian,and frogger.
My new PCB has 19 games in it.Moon Patrol you have to jump,so i need to add that second button.When i get my Kung Fu Master board i'll need to kick.It is a Jamma harness.
tommy:
If you only have one button hooked up you should have two more on the jamma harness you could use.
mvarady:
I know that.All i need to know is what kind of wire and connectors do in need.Thats all.and where to get them.
SirPoonga:
you need to hook up through jamma harness.
See a jamma pinout.
http://www.coin.demon.co.uk/jamma.htm
