Author Topic: best place to mount your power button  (Read 1193 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: June 13, 2005, 10:17:36 am »
I have the 2 X 2 large square led,  I'm going to hack the switch on the motherboard to make a full system power on/off switch two questions...
1. what is the best place for this, i was thinking about above the coin door & below the controller
2. also i assume i will have to run a additional 2 wires to power the bulb in the led switch off of the computer power supply so 4 wires total 2 to motherboard & 2 to power supply
thanks
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: best place to mount your power button
« Reply #1 on: June 13, 2005, 10:36:05 am »
I have my power button hidden in my keyboard drawer so that it doesn't accidentally get hit.
  This is true.  Just make sure you have the voltage right for the LED and use a resistor if you need one. (I don't know what I'm talking about, but hopefully you do :) )
-sab
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: June 13, 2005, 10:39:23 am »
Top of cabinet side on the right near the back.
namedos
  • Last login:January 04, 2023, 06:18:13 pm
« Reply #3 on: June 13, 2005, 11:57:45 am »
Depends on what kind of cabinet you have.  A lot of the original cabs have a power button on the back side or bottom to prevent anyone from accidentally turning it off.
I built a UAII and used a very unobtrusive switch and mounted it on the side right underneath the upper side panel.  Easy to reach and not easy to see.
I would think the coin door would work fine as long as you're willing to open and close it a lot.
Yes, you need two sets of wires - one to control the switch that goes to your motherboard.  One set from a molex or other means to get power to the LED.
divemaster127
« Reply #4 on: June 13, 2005, 12:07:50 pm »
hello, i have the slilkstik with quad 4
thanks
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #5 on: June 13, 2005, 12:10:54 pm »
Put mine under lock and key behind the coin door. It prevents the inquisitive little hands of children from trying random buttons / switches.
-Goz
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #6 on: June 13, 2005, 12:13:56 pm »
My MKII cab has a switch recessed into a hole on the top of the cab near the back left corner
My candy cab has a switch under the bottom near the front kick panel
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: June 13, 2005, 12:29:47 pm »
Mine's mounted behind a zipper.
NO MORE!!
ethous
  • Last login:March 31, 2015, 04:38:35 am
  • Life is prescious enjoy every minute
« Reply #8 on: June 13, 2005, 01:13:35 pm »
I actually mounted mine to the coin door Cherry switches I had a 4 slot door.
1 is my Power the other is my reset the other 2 are credits.
So a good old quarter will turn it on or if lazy can open it up and flip switch once
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #9 on: June 13, 2005, 09:59:44 pm »
Dude, that is NOT RIGHT.
ROTFL
-- Chris
Underway: Joey's Arcade
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #10 on: June 13, 2005, 11:52:49 pm »
ROTFL
Hmmmm... is it a micro-switch   :laugh:
-- Chad Tower
