Main > Main Forum
where can i buy black contact paper?
Pages: << < (4/4)
Kev-in DFW:
Alan,
I sprayed my cabinet with enamel using a cheap air sprayer I picked up at Harbor Freight.
alundra:
--- Quote from: Kev-in DFW on June 11, 2005, 08:53:06 pm ---You can pick up Wilsonart plain black laminate in a 60 finish (semi-gloss) at Home Depot for about $50.00 a sheet.
Kev~
$50 a sheet..Jesus!! :o when Happ sell vinyl sheet for only 5 bucks!!!
quarterback:
--- Quote from: alundra on June 12, 2005, 01:02:27 am ---
Kev~
Happs sells vinyl for about $5 PER FOOT
M3talhead:
--- Quote from: quarterback on June 12, 2005, 03:16:55 am ---
Kev~
He's right. Happs screws people on vinyl. Go with Parts Express. Its exactly the same product, but a lot cheaper.
Parts Expres sells the same vinyl as Happs. Happs just overcharges way to much. For the 4 rolls I used, it cost around $68. I had plenty of leftovers (almost an entire roll).
pcb:
--- Quote from: M3talhead on June 12, 2005, 04:54:39 am ---He's right. Happs screws people on vinyl. Go with Parts Express. Its exactly the same product, but a lot cheaper.
It may be the same stuff, but is it as wide?  If you don't want a seam down the middle of the cabinet, go with full sheets from Happ, Unless your cab doesn't require anything wider than 24".
Pages: << < (4/4)
Go to full version
