Author Topic: Possible to Use CPS3 on TV?  (Read 1649 times)
shodokan123
  • Last login:October 14, 2007, 01:57:20 am
  • Fighting Game Addict
« on: June 09, 2005, 01:56:13 pm »
title
Gootfu
  • Last login:September 09, 2005, 02:56:50 pm
  • no what I'm s-s-sayin'?
Re: Possible to Use CPS3 on TV?
« Reply #1 on: June 09, 2005, 03:52:38 pm »
How about using a video encoder...
http://www.jrok.com/hardware/RGB.html
Over my window they'd written my name,
Saying so long and see you again.
shodokan123
« Reply #2 on: June 09, 2005, 03:58:37 pm »
i'm not sure i'm experienced enough to do that... i dont want to spend the 100+$ on the cps3 + game and then ---fudgesicle--- it up big time..
AlanS17
    • AlanS17
« Reply #3 on: June 09, 2005, 04:53:40 pm »
The video encoder won't hurt the board. I don't think they're cheap, though.
shodokan123
« Reply #4 on: June 09, 2005, 05:48:33 pm »
it wont hurt the board? how so?
it gives u a warning on the site that it will screw up ur tv, power supply etc if u screw up.
AlanS17
    • AlanS17
« Reply #5 on: June 09, 2005, 07:07:02 pm »
I suppose you could cause a short if you wire it up wrong, but the wiring is extremely straight forward. I don't know what sort of a problem a short might cause.
The red wire carries the red signal. The blue wire carries the blue signal. You get the idea. Black carries ground and the one left over carries sync.
R/G/B/ground/sync
Tada! All those lines are clearly labeled on a JAMMA harness diagram. Sometimes they're even printed right onto the JAMMA harness.
In all honesty, the item most prone to damage would be the converter, itself.
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #6 on: June 09, 2005, 08:06:04 pm »
Isn't Street Fighter III (New Gen, Double Impact and 3rd Strike)  the only series using CPS3???? Couldn't you just hook a dreamcast up and get all three in the series up and working with ease? I think so, but maybe you have other plans.
shodokan123
« Reply #7 on: June 09, 2005, 09:33:27 pm »
dreamcast isnt arcade perfect..
and there is a sf3:3s with cps3 on ebay i could win for like 150
stellarola
« Reply #8 on: June 09, 2005, 09:44:53 pm »
I was just curious how it's not arcade perfect? Like what are the differences and similarities? I'm being completely serious too, like I dunno, so please fill me in  :). I was wanting to buy 3rd strike cps3, but I figured the dreamcast version was the same  :P.
paigeoliver
  • Awesome face!
« Reply #9 on: June 10, 2005, 02:36:14 am »
CPS3 on a TV won't be arcade perfect either, you take a hit in image quality when going from RGB to composite. The dreamcast will actually look better.
Anyway, why play it on a TV? You'll spend less money on an actual JAMMA cab to install it in then you will on hooking it up to a TV.
