Author Topic: 27" TV and Showcase Cabinet - Will it work?  (Read 1172 times)
nickbuol
  • Last login:July 20, 2023, 03:27:15 pm
  • 2nd Time Around
« on: June 07, 2005, 12:55:47 pm »
OK, I know that it will "work" but is 27" too small for a showcase cabinet?
I believe Hulk used a 27" in his Mamestrosity showcase cabinet.
I had a nice (better than the tv in my living room) 27" TV in my first cabinet, but i sold the cabinet, and lept the TV for my next cabinet.  I thought that I was going with the classic "Lusid" cabinet (no real modifications outside of it being 4 player this time), but I did that last time, and I had to "spice it up" a little to make it more unique.  I went with a top marquee curve like Robocop, and the bottom like Mortal Kombat and SmashTV.
So now I am thinking that I want something different again, but is 27" too small?  I am already over budget on my projects around the house, so I can't go out and buy a 33" TV.
Thanks for your ideas and input.
Q*Bert_OP
  • Oh yes, we did!
Re: 27" TV and Showcase Cabinet - Will it work?
« Reply #1 on: June 07, 2005, 04:52:44 pm »
are you refering to Dynamo showcase cabs?
All of 'em in my area use 33'' or 39'' monitors.
AlanS17
    • AlanS17
« Reply #2 on: June 07, 2005, 05:54:19 pm »
I think a 27" TV would look small.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #3 on: June 07, 2005, 06:38:12 pm »
Probably too small for a showcase. But hey, if 27" is the best you can do, then it is the best you can do. If anyone comes over and says "great cabinet, but the tv is too small" tell them to get the hell out. ;D
That's what I plan to do if anyone criticizes my construction flaws. ;)
Apollo
    • Eight Bells
« Reply #4 on: June 07, 2005, 06:53:20 pm »
Why don't you just construct your cab so that when/if you decide you can put a bigger screen in there you can.
nickbuol
  • 2nd Time Around
« Reply #5 on: June 07, 2005, 09:23:52 pm »
I thought about that too, but then I thought that I might be over-emphasizing that the TV is really too small for the cabinet.
I think that I will stick with my original plan.  Thanks for the input everyone.  I will leave the Dynamo showcase style to someone with a larger TV...
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #6 on: June 07, 2005, 11:27:13 pm »
Some of the real showcase cabs have only a 27" monitor.  It might be ok -- It depends how far away the controls are.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #7 on: June 22, 2005, 04:36:01 pm »
hey, i was just browsing through this forum and i saw this question.  no, a 27" tv is not too small.  but then again, my monitor encasing is custom built and not from plans or anything.  but it definitely does not look too small.
