Author Topic: Volts vs Amps  (Read 1663 times)
Volts vs Amps
« on: June 07, 2005, 09:48:17 am »
I'm studying up on electricity itself in prep for some projects I want to start in the near future.  I want to be sure I really understand some concepts and am hoping someone can confirm (or refute) some analogies I'm working on in my head.
I'm thinking of electricity, as I've read, as water in a pipe.
Voltage = forward water pressure. The more voltage, the faster the water will come out THE END of the pipe.  Voltage has a vector parallel to the walls of the pipe.  Too many volts will damage whatever the water is feeding into (e.g. the sprinkler at the end of the hose).
Amperage = amount of water in the pipe, pressure on the pipe walls.  Amperage has a vector perpendicular to the walls of the pipe.  Too many amps will cause the pipe walls to burst.
Are those analogies reasonable or am I misunderstanding something?
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
Re: Volts vs Amps
« Reply #1 on: June 07, 2005, 10:20:56 am »
http://science.howstuffworks.com/question501.htm
See, everyone uses the water analogy :)
Re: Volts vs Amps
« Reply #2 on: June 07, 2005, 10:46:43 am »
Yeah, I was using the water analogy because I've seen reference to it, and it makes sense.  Visible physical force is easier to wrap one's mind around than "theoretical" force.
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
Re: Volts vs Amps
« Reply #3 on: June 07, 2005, 11:06:22 am »
http://www.bcae1.com/
I point people there with this question because their water diagrams are perfect IMHO.  It's a car audio site, so it won't all apply to you (unless that's your project lol), but there is a LOT of good info there.... volt, amp, current, ohm, et al.  There are some good diagrams as well.
first off your and idiot
Re: Volts vs Amps
« Reply #4 on: June 07, 2005, 11:20:16 am »
No, actually I'm trying to master the concepts involved so that I can dive deeper into monitors, vectors specifically, for an upcoming cab I'd like to design.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
Re: Volts vs Amps
« Reply #5 on: June 07, 2005, 12:37:36 pm »
Chad, did you ever finish fixing your AD?
If not, don't you think you should walk up the hill before trying to scale a mountain?
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
Re: Volts vs Amps
« Reply #6 on: June 07, 2005, 12:53:56 pm »
Haven't worked on it, have been working on other things.
The primary holdup for the AD hasn't been the conceptual part, it's been my suckass soldering skills.  I won't touch the AD PCB until I'm confident I won't wreck it, and the problem is in the X/Y video section of the PCB.
My attention span is too damn short, I tend to work on 10 projects in parallel and none of them go very quickly.
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
Re: Volts vs Amps
« Reply #7 on: June 07, 2005, 08:40:10 pm »
if you think of the voltage in terms of a water tank, then the height of the tank is analogous to the volts, and the size of the pipe the amps and naturally the length of the pipe is resistance. the analogy works well because you can use the same 'pascals triangle' formula to describe them both...
  • Last login:May 06, 2024, 04:33:26 pm
Re: Volts vs Amps
« Reply #8 on: June 07, 2005, 09:13:49 pm »
If you really wanna bake your noodle, study RLC circuits for a while!   ;D
NoOne=NBA=
Re: Volts vs Amps
« Reply #9 on: June 07, 2005, 10:34:01 pm »
Volts = Water Pressure
Amps = VOLUME of the water through the pipe
Resistance = Size of the Pipe
If you increase the voltage (turn up the water pressure) without changing the resistance (using a different sized pipe), the amperage will increase (water will flow faster through the pipe).
If you decrease the resistance (use a bigger pipe) without changing the voltage (keep the same water pressure), the amperage will also increase (more water will flow through the larger pipe).
Would you like to hear my "cattle roundup" description of how a transistor works?
DarkKobold
Re: Volts vs Amps
« Reply #10 on: June 08, 2005, 06:32:39 pm »
NoOne=NBA=
Re: Volts vs Amps
« Reply #11 on: June 08, 2005, 06:43:10 pm »
No one would steal this avatar..
I would NOT.
I like mine very much...thank you.
forbiddenlyrics
  • Last login:July 10, 2010, 03:19:34 pm
  • I'm Bart Simpson Who The Hell Are You?
Re: Volts vs Amps
« Reply #12 on: June 08, 2005, 11:07:10 pm »
I second this! I just finished my third circuits class yesterday and my brain is fried for awhile.
Navmaxlp
  • Last login:November 08, 2014, 02:40:57 pm
Re: Volts vs Amps
« Reply #13 on: June 08, 2005, 11:19:39 pm »
If any of you ever have any questions dealing with electronics, I am an electronics technician with the FAA. I was military trained (GO NAVY) and have been doing this for quite a long time. Please feel free to PM or post if you need help with anything. I know how the concepts sometimes are hard to grasp at first but once you understand it its easy. Good luck with the tuned tank circuits (RLC networks) and beware the transistor/JFET/MOSFET biasing area of intsruction. Not to scare you or anything hehe
Just a few things for those who may not know since i think more in math than in words
E(voltage) = I (Amps) X R (Resistance)
P (Power) = I (Amps) X E (Voltage)
Something basic for you guys starting out.
« Last Edit: June 08, 2005, 11:25:19 pm by Navmaxlp »
Joystick Jerk
  • Last login:October 22, 2023, 08:18:08 pm
  • Slave to the stick.
Re: Volts vs Amps
« Reply #14 on: June 08, 2005, 11:53:20 pm »
Volts shock/burn you, amps kill you. As long as you stay on the good side of amps, volts won't cause you much harm(relatively speaking).
« Last Edit: June 09, 2005, 12:00:47 am by Joystick Jerk »
Re: Volts vs Amps
« Reply #15 on: June 09, 2005, 08:55:29 am »
The problem is, he is going to have to if he wants to do his project.
I think Chad was talking about making his own 25" vector monitors. Lots of inductance, capacitance, and EM there.
Soldering just takes practice Chad.... Find some crappy pcbs and start soldering to them.
Yep... my problem is that every time I get my workbench clear, my wife stacks 50 things on it.  It's like she sees a clear spot and thinks "hey, I can put some crap there."  I do something fundamentally wrong when soldering, I had trouble even reflowing last time.  I had to sit the tip directly on the solder blob for 20 seconds before it would even start to melt.
Navmaxlp
Re: Volts vs Amps
« Reply #16 on: June 09, 2005, 09:03:49 am »
One thing you can do to speed up the heat transfer is put a little solder on the tip first before you start to desolder a joint. Also tro to get as much of the iron surface area on the joint as you can. And lastly keep as much metal from touching the joint as possible ie dont hold the joint with a pair of pliers. Not only can this burn you but, it also dissipates a lot of heat. The more heat you dissipate the more it will take for the solder to melt. Oh and wick is easier for me to use than a solder sucker but, thats a matter of opinion. Hope that helps.
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
Re: Volts vs Amps
« Reply #17 on: June 09, 2005, 12:03:17 pm »
I have this same problem with my cocktail. Flat surfaces attract crap.
97.4 percent of all statistics are full of crap.
danny_galaga
Re: Volts vs Amps
« Reply #18 on: June 09, 2005, 08:26:20 pm »
Shooter
  • Last login:January 21, 2009, 11:45:52 pm
Re: Volts vs Amps
« Reply #19 on: June 09, 2005, 09:13:20 pm »
Wow that is weird I also was Navy trained (ET2) and i now work for the FAA (Milwaukee).  It is a common transition from what i have heard.  Most of our techs are ex military.  I'm going to ILS school later this year.
Shooter
Navmaxlp
Re: Volts vs Amps
« Reply #20 on: June 09, 2005, 09:23:33 pm »
ILS concepts or an equipment course? I just had the Mark 1f OJT and am awaiting the cert exam hehe.  I'm in Baltimore but, I start VORTAC school in June. Let me know if you'll be out there at the same time, we can hit Red Dog LOL. BTW what ship were you on in the Navy?
« Last Edit: June 09, 2005, 09:25:42 pm by Navmaxlp »
Shooter
Re: Volts vs Amps
« Reply #21 on: June 09, 2005, 09:53:00 pm »
I'm heading down there Monday for 10 weeks.  Going to the new hire class then after that its on to ILS concepts.  This past week i helped install a mk1f, I learned a ton from that.  You should look me up. I'll probably be at Mansions North.
My ship was the USS Mitscher (DDG 57)
Shooter
Navmaxlp
Re: Volts vs Amps
« Reply #22 on: June 09, 2005, 11:30:09 pm »
I always stay at mansions north. Best by far imo. Just a warning. If you haven't taken vor concepts yet, ils concepts can be a bear of a course. It sucks when the normal rules of electronics no longer apply. I'll PM you once I've booked my room.
Re: Volts vs Amps
« Reply #23 on: June 10, 2005, 08:37:30 am »
clean is good, and is the iron powerful enough for the job? the hotter the better (within reason) as you can do the job so much more quickly which means less total excess energy is going into the component...
Unless it's faulty, it should be.  20/40W station.
Shooter
Re: Volts vs Amps
« Reply #24 on: June 10, 2005, 05:55:41 pm »
I agree I had a 45 Watt iron and it really was more then I needed so I went to a switchable 15W/30W iron and it works great.
danny_galaga
Re: Volts vs Amps
« Reply #25 on: June 10, 2005, 10:21:57 pm »
note that P (power) is in watts. in australia we just refer to it as W (watts)
