Main > Main Forum
Adding a matrix to a keyboard encoder?
Tiger-Heli:
--- Quote from: RandyT on June 05, 2005, 06:42:27 pm ---Here's another option for you:
Use a KeyWiz Eco and wire up 4 more (or however many you need) dual-diode "one-click Shazaaam" buttons.
This will work except Lilwolf didn't even want to pay the initial $20 for the Eco.
I have a very detailed page on the theory and how-to (more than you need to know) at http://www.mameworld.net/emuadvice/keyhack2.html, and IMHO, Spystyle has the best "short and sweet" tutorial at http://spystyle.arcadecontrols.com/index79.htm
RandyT:
--- Quote from: Tiger-Heli on June 06, 2005, 06:37:01 am ---This will work except Lilwolf didn't even want to pay the initial $20 for the Eco.
Actually he said:
--- Quote from: Lilwolf on June 05, 2005, 02:57:37 pm ---I don't think it would be worth my time for 20 bucks and a keywizeco.... unless I had to buy two.
Which I took as, paraphrased, unless he needed to buy two, the effort of hacking the keyboard wouldn't be worth it. I was just saying that it could be accomplished without buying 2 units by just wiring a few buttons with some diodes. ;)
But hacking a keyboard is still a viable option for a jukebox, and those links will certainly help get the job done!
RandyT
Tiger-Heli:
Re-read the original post and now agree with Randy.
It now sounds like Lilwolf is saying the time to hack the keyboard would be worth more than the $20 for the Eco, unless he had to buy two.
A third option would be to use an Eco and hack a gamepad for the additional 3-4 inputs, but if you're going to hack something regardless, IMHO, you might as well just do it once with the keyboard.
SirPeale:
Re-read the original post myself, and I definitely stand by my original advice: a keyboard hack would be the best way to get the input. It wouldn't take much time to map the matrix, AND there would be a vast amount of keys to use.
Lilwolf:
Time seems to be harder to find then 20 bucks these days. I'm now steering towards the shazam + diodes method.
1/2 because I haven't bought anything from Randy yet. And figuring no matter how good I am.. it will take more then an hour and not look as good.
One other option might be to wire up one of the printer port adapters also. But I think I am going to put that one off for the same reasons.
But I will pull apart a few of my really old keyboards and see if it will be trivial (no soldering)... otherwise I'll probably get an Eco board.
