Author Topic: how do you light up your see-thru trackball??  (Read 1130 times)
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« on: June 03, 2005, 11:07:20 pm »
Sorry I'm at home with super slow internet so I'm being lazy and not searching tonight!
I'm talking brand names and websites people! I bought a "led cannon" off the internet and I'm still waiting for the cannon part...I have to turn the light off and squint before I realize the thing is even lit up!!
Any advice? Can I just hook up a spotlight to a car battery or something? :p
stevodevo
NoOne=NBA=
Re: how do you light up your see-thru trackball??
« Reply #1 on: June 03, 2005, 11:28:04 pm »
I got some 6v incandescent flashlight-style bulbs from Radio Shack, the bases for them, and a 6v power supply to run them.
At the moment, the bulbs are just taped to the bottom of the trackball case.
I may get around to actually mounting them properly someday, but they work for now.
DreamArcades
  • Last login:April 26, 2022, 05:36:40 pm
    • Dream Arcades, LLC
« Reply #2 on: June 04, 2005, 03:43:55 am »
I used LED's with good sauces. They are very directional, so make sure your LED is pointed right on the trackball. If this doesn't work you might have got a dim LED. I usually use three LED's.
I've done the 12 volt lamp as well. Both work fine.
stevodevo
« Reply #3 on: June 06, 2005, 03:48:38 pm »
Thanks guys!  I did move the led so that it was *almost* directly under the trackball (unfortunately that is where the hole is in my control panel box to let cords out) and that helped quite a bit.... still not as bright as some of the other guys control panels I've seen.
But that works for now!  I may try more leds or the 6v bulb solution in the future...getting married friday so i gotta save my pennies!
stevodevo
ahofle
    • Arcade Ambience Project
« Reply #4 on: June 06, 2005, 03:59:56 pm »
I have a super bright LED cannon.  It's a single LED and it's so bright, it shines through my green trackball and puts a spot on the ceiling.  I'm guessing either yours isn't a superbright, or something is wrong with it.  It hurts my eyes to look directly at it, it's that bright.
KevSteele
  • Last login:November 01, 2021, 08:42:43 am
  • Retrogaming Media Mogul in Rehab
« Reply #5 on: June 06, 2005, 04:38:28 pm »
Okay, I'm not familiar with this technique. Any sauces in particular...A1 perhaps?
I used a 4-led cluster:
http://www.retroblast.com/reviews/lazer.html
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
stevodevo
« Reply #6 on: June 07, 2005, 01:03:15 pm »
yeah that saucy response kinda threw me off too!
namedos
  • Last login:January 04, 2023, 06:18:13 pm
« Reply #7 on: June 07, 2005, 05:39:37 pm »
12V super bright LED wired with a lead off a molex splitter.  I believe it is a five bulb red LED and it puts off plenty of light.
