Author Topic: Do you need a QUIT button on your control panel??  (Read 2374 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: June 02, 2005, 02:41:36 pm »
this might sound like a daft question but whilst i was planning my cp layout I suddenly thought that if I don't somehow wire up a QUIT button how am I going to quit a game and go back to the mame front end?
on all of the cp's i've seen i've not seen any that specifically mention a quit button.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
Re: Do you need a QUIT button on your control panel??
« Reply #1 on: June 02, 2005, 02:42:38 pm »
If you are using an IPAC, I believe the default "escape" key combo is P1 & P2.
Personally, I don't like that, and am putting in a dedicated Escape key button.
eggedd2k
« Reply #2 on: June 02, 2005, 02:44:49 pm »
thanks.
AlanS17
    • AlanS17
« Reply #3 on: June 02, 2005, 02:49:06 pm »
Yeah you can quit any game by hitting P1 and P2 start buttons simultaneously with an Ipac. However, you might be better off just remapping it. I've had plenty of times where 2 people go to hit start at the same time (especially in fighting games) and the games accidentally exits. In that case you'd want an "exit" button or a less sensitive exit button combination.
eggedd2k
« Reply #4 on: June 02, 2005, 03:24:18 pm »
i'll have to check my i-pac pcb. does it have a quit terminal that a button can be wired to??
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« Reply #5 on: June 02, 2005, 03:27:44 pm »
On my first cab (using a keywiz) I didn't bother to designate a button solely for quitting. But since then I make a point of adding one. It's extremely convenient, especially when you're entertaining people and you don't want to explain how to exit the game.
If I'm working on a MAME I consider it a necessity. And it's one of those buttons you can easily hide - you don't need it on the CP.
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #6 on: June 02, 2005, 03:31:27 pm »
I consider exit to be like credit, you have to have it.
Personnaly, I have never understood why people map exit to P1 and P2 start. Of all the combinations...
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
markrvp
  • NFL Expert
« Reply #7 on: June 02, 2005, 03:35:04 pm »
There is not a "Quit" terminal.  I hooked mine up to Player 1, Button 8 and changed it's mapping to ESC using the WinIpac utility.
Lilwolf
« Reply #8 on: June 02, 2005, 03:37:16 pm »
I hate the p1 and p2 combo.  I just got an IPac recently (used mk64 before then) and I haven't disabled it yet...  (lack of time)
but I got knocked with that last night...  almost made my 5 year old cry... (because she thought I was quitting the game because it was bedtime)
AlanS17
    • AlanS17
« Reply #9 on: June 02, 2005, 03:51:22 pm »
Yeah there are more buttons on an IPAC than you'll ever use. Just pick a button 7 or button 8. The IPAC wasn't built with menu buttons in mind, only game play buttons. All the menu buttons are activated by a combination of game play buttons.
Stingray
« Reply #10 on: June 02, 2005, 03:54:54 pm »
Never had a problem with the P1 + P2 combo myself. Of course my MAME cab doesn't have a credit button either. You have to put tokens in it just like with my dedicated machines.
-S
Dire Radiant
  • Last login:March 25, 2011, 03:11:36 am
  • Cor, chief!
« Reply #11 on: June 02, 2005, 03:55:56 pm »
If you're the only one using it then combos are fine. However one of my ironclad design principles for my cab is that any person of average intelligence should be able to walk up to it, launch a game, play, quit the game, launch the jukebox, play a song, switch back to Mamewah and play another game without any instruction from me and preferably without reading an instruction card. That makes a clearly laid out admin panel essential. Luckily my cab has a perfect place for the admin panel to go. Others may not be so lucky if doing a conversion.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:37:55 pm
« Reply #12 on: June 02, 2005, 04:07:22 pm »
check my CP on my page. Dedicated EXIT button and dedicated Help button.
Free VGA Breakout Cable
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #13 on: June 02, 2005, 06:30:16 pm »
My design principle for my cabinet is : "I don't want to help".
As soon as a friend asks me "How do I...?", a part of me dies inside.
So having a dedicated Quit button was essential for me.
You can see from my control panel that I have the following dedicated buttons:
Escape (Which I should have called QUIT)
Next List
Previous List (This doesn't seem necessary anymore since I don't have very many lists)
Save Game
Load Game
Volume + (These are kinda optional, people don't seem to care about the volume much and lots of designs just use a knob sticking out somewhere or hidden somewhere)
Volume -
Pause
Some functionality I've added since I designed my control panel:
The Next List did nothing in MAME, so now it brings up the Command List
The Previous List also did nothing so now it brings up the Cheat List. Although maybe cheating shouldn't be so accessible? ;)
Joseph Elwell.
Dire Radiant
  • Cor, chief!
« Reply #14 on: June 02, 2005, 06:39:28 pm »
Now having a help button - that idea I like. What does yours actually do?
Thenasty
« Reply #15 on: June 02, 2005, 06:43:37 pm »
check my site, it shows you. I'm working on putting on the site when you push HELP while a game is loaded. I have posted a pic here berfore but I'm trying to put everything in my site.
Veinman
« Reply #16 on: June 02, 2005, 11:06:14 pm »
My CP will have a row of 5 admin buttons. Current plans for their functions, in order, are:
Escape
Shift (alt button for the IPAC)
Load
Save
Pause
I feel that Escape and Pause are buttons that are always going to be needed, so I was wondering if I should actually have the words "Exit" and "Pause" printed on the CP above the buttons.
Alternatively, I can put a small instruction card on showing the buttons and their functions under the bezel, or maybe even print out the words myself and stick them on top of the printed CP, which will be covered with lexan.
The advantage is flexibility, at the possible cost of some aesthetics. What do you think? Did any of you print words on your CP, only to regret it later?
markrvp
  • NFL Expert
« Reply #17 on: June 03, 2005, 02:09:16 am »
I'm adding a NAV bar under the monitor on my cab.
DreamArcades
  • Last login:April 26, 2022, 05:36:40 pm
    • Dream Arcades, LLC
« Reply #18 on: June 03, 2005, 02:12:08 am »
Don't forget the [Tab] key for getting into the ROM menu.
-mike
paigeoliver
  • Awesome face!
« Reply #19 on: June 03, 2005, 02:46:54 am »
Next List
Save Game
Load Game
Volume -
Pause
Joseph Elwell.
Hee hee, the control panel looks like you spilled a bag of skittles on it!!!!! (Nice build quality though).
I hope, I hope, I hope that is a temporary monitor, its a shame to match up that awesome panel with a 17" or 19" PC monitor that is dwarfed by the panel.
Veinman
« Reply #20 on: June 03, 2005, 07:59:04 am »
-mike
I plan to manage that one through use of the alt button somehow. I don't find myself using that very much at this point in time, but I'm sure I'll use it more in the future.
Chris
    • Chris's MAME Cabinet
« Reply #21 on: June 03, 2005, 09:46:36 am »
There's only so big of a monitor you can cram into that size of a cabinet. If that's a 23" wide cab like mine, it's 3/4" too small for the common 27" monitors, and 25" monitors are darn hard to find.
My panel has three admin buttons: Pause, Exit, and a dedicated Shift button to access everything else.  And yes, Paige, it also looks like a bag of skittles spilled on it; I'm not fond of monochrome panels.  (I remember arcades as colorful places.)
--Chris
Bones
  • [Moderator]
« Reply #22 on: June 03, 2005, 10:13:23 am »
I have dedicated admin buttons with unique IPAC inputs for Esc, Tab, Shift and F10.
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #23 on: June 03, 2005, 10:48:16 am »
I have dedicated pause and exit buttons, as well as <Enter> and <Tab> to get to the menus.
If you have kids, you gotta have a pause button.
Too bad it doesn't work on them
« Last Edit: June 03, 2005, 10:50:55 am by Dougmeister »
Chris
« Reply #24 on: June 03, 2005, 11:07:14 am »
Thinking about adding the save/load buttons...
I use the flipper buttons and PAUSE for this.  Left flipper/PAUSE saves, right flipper/PAUSE loads.  Because of the way this function works, both automatically save and load from position "P" (which is what PAUSE is mapped to), so I don't need the extra step of specifying a save/load position.
Edit: Chris and jelwell, nice CPs.
--Chris
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #25 on: June 03, 2005, 12:16:09 pm »
Instead of having an Exit and Select button...you could just make a Select/Exit button in one. You select the game in your favorite frontend, which is mapped in the frontend, and then you make the same button the exit button in Mame mapping, by hitting TAB....easy nuff, right?
Veinman
« Reply #26 on: June 03, 2005, 01:17:45 pm »
I hate to self-quote, but I'd love to hear some thoughts on printing words on the CP overlay.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #27 on: June 03, 2005, 03:33:58 pm »
That sounds good, but would there be a "key repeat" that might cause the front-end to then immediately re-start a game?
NO MORE!!
jelwell
« Reply #28 on: June 03, 2005, 04:16:47 pm »
It's sorta temporary. It's currently a 19 inch PC Monitor. I'm waiting for someone to donate a 21 inch PC Monitor, or for me to become wealthy enough to buy a nice 25 inch Arcade Monitor (assuming that's the largest that will fit). I bought a real bezel, so it looks a lot cleaner now:
paigeoliver
  • Awesome face!
« Reply #29 on: June 03, 2005, 04:32:01 pm »
A 25" will just barely squeeze in, and that is pretty much a minimum considering the sheer size of that panel.
Is that thing front heavy, I mean, does it want to tip over if you push down on the panel?
RayB
  • There's my post
    • RayB.com
« Reply #30 on: June 03, 2005, 04:53:28 pm »
What the...?!  Do you have a rotating marquee?
NO MORE!!
jelwell
« Reply #31 on: June 03, 2005, 07:12:19 pm »
Nope. Not at all. Not only that, but you can see from some of the pictures that the cabinet is resting on a furniture dolly - which you would think would lend even more stability problems to it. But it doesn't. Try lifting an arcade cabinet with a 19inch CRT in it and coin door mechs! That's a whole lot of counter-balancing weight. ;)
My concern with upgrading to an Arcade Monitor is that I love Virtual Pinball and I'm afraid I'll lose too much resolution/clarity. My friend has a TV in his cabinet and Visual Pinball looks awful.
What the...?!
jelwell
« Reply #32 on: June 03, 2005, 07:23:01 pm »
Any button on my control panel that doesn't do anything in MAMEWAH will launch the selected game. Which means all the player buttons including STARTs and CREDITs. But none of the "Function" buttons.
People seem to understand hitting the Player 1/2 Start button, to load a game.
Dire Radiant
  • Cor, chief!
« Reply #33 on: June 03, 2005, 09:47:10 pm »
Only when planes land on it! ;D
