Author Topic: Any Laminate (Wilsonart) Experts Out There....  (Read 1557 times)
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« on: June 01, 2005, 10:49:20 pm »
Greetings!
I have created a "built out" coin door panel for my cabinet:
I spent quite a bit of time smoothing out the radii on the "S-Curve" shape of this assembly:
Bottom line, I don't want to mess it up when I try to apply the laminate (black Wilsonart) to it.
My current plan is to apply it to the flat, upper surface first, and then  J-Roll gradually around the upper (outside) radius, then down the sloped panel around the lower (inside) radius and onto the flat part of the lower panel.
On a flat panel, I would use vinyl blind slats to keep the laminate up as I worked out from the center.  Here, however, everything isn't flat, and as I start around the curves, the laminate is going to want to touch at points I don't want.  I'm thinking about a large sheet of brown "package wrap" paper used as a slip sheet.
Will this work?
Are there any laminate application experts out there that can offer tips, or a better strategy?
Cabinet construction (in progress) page:
http://www.ogredog.com/mame_construction_home.htm
« Last Edit: June 01, 2005, 10:51:31 pm by tivogre »
tivogre
    • ogredog.com
Re: Any Laminate (Wilsonart) Experts Out There....
« Reply #1 on: June 07, 2005, 07:30:27 pm »
Well, it's done!
I learned some things along the way, the most important of which was that the 1" radius curves I had were NOT sufficient.
The full saga of the lamination can be found on my web update:
http://www.ogredog.com/mame_construction_home.htm#Day%2024%20&%2025
Tailgunner
« Reply #2 on: June 07, 2005, 08:49:22 pm »
Good job, it turned out nice. Sounds like you had quite a fight to get it follow the curves.
Did you check the installation guides on the Wilsonart website? There are different grades and thicknesses of laminate, some of which will follow a 5/8" curve without heat.
dema
  • Last login:September 02, 2014, 03:05:34 am
« Reply #3 on: June 08, 2005, 02:48:56 am »
That looks beautiful!
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #4 on: June 08, 2005, 07:13:20 am »
Beautiful work.  I'm a real fan of laminate and it's finished look.  I agree, it's a pain to work with, but I believe it's worth the effort and really provides a professional finish to a cabinet.
fiscap
  • Last login:September 10, 2023, 08:10:16 pm
  • I dare ye enter... the dungeons of daggorath!!!
    • BYOAC blog
« Reply #5 on: September 30, 2005, 02:07:11 pm »
I noticed that you're using Wilsonart on your cab. Did you purchase through a local store or were you able to find a decent retailer on-line?
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« Reply #6 on: September 30, 2005, 03:34:45 pm »
Great wood working job, you certainly put more into than I did on mine. If you weighed that thing would it measure in metric tonage  ;D
great work...
The Way Back Machine - http://www.taborious.com
dema
« Reply #7 on: September 30, 2005, 03:35:34 pm »
I believe the laminate they carry at Home Depot is WilsonArt.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #8 on: September 30, 2005, 06:28:02 pm »
That is NICE.
Next I'll be on fries, and that's when the big money starts rolling in.
tivogre
    • ogredog.com
« Reply #9 on: September 30, 2005, 08:21:27 pm »
I contacted Wilsonart and asked for the name of a local distributor.
After a couple of phone calls, I found one from their list that would sell to the public.  There was a 10 sheet minimum order.... so I went in with a friend who was building a cabinet too.
We bought 14 sheets between us at $22.00 per sheet.  That was about $20 less per 4x8 sheet than Home Depot wanted.  We were also able to get the thinner "vertical grade" laminate through the distributor that Home Depot didn't have available... even through special order.
The vertical grade is thinner and lighter.  That has good points and bad points...  It is CAPABLE of bending around a smaller radius... BUT it is more brittle and less forgiving.  It also puts less stress on the adhesive on the side panels.
fiscap
    • BYOAC blog
« Reply #10 on: April 18, 2006, 01:33:18 pm »
Yikes! I found a local retailer of Wilsonart laminate and they want $2.75/s.f. for five 4x8 sheets - $440!! That's almost twice the price of what Home Depot charges. I asked them about pricing for vertical laminate as you indicate Tivogre - but they had no clue what I was talking about.
Oh well - I'll keep searching.  :-\
** As an update to this post, I've found an online supplier of Wilsonart Laminate - http://forum.arcadecontrols.com/index.php?topic=54691.0
« Last Edit: June 12, 2006, 04:39:27 pm by fiscap »
JDShaffer
  • Last login:September 30, 2014, 10:15:59 am
« Reply #11 on: April 19, 2006, 12:12:08 pm »
I have been going through the website for a few weeks now and I just am amazed at the awesome work some of you do.  Very nice.
