Author Topic: HOT DAMN!!! This stuff works!!!  (Read 1857 times)
AlanS17
    • AlanS17
« on: May 26, 2005, 12:23:40 am »
Keep reading. The good stuff is down there.
I was looking for a way to get permanent marker off of formica. I was going to try brute force, but some very helpful people i another thread pointed me to something called Goof Off. I learned a few things:
1.) The stuff will burn your nose hair
2.) I think it helped my sore throat
3.) It'll make you dizzy
4.) It doesn't burn the front of your hand, but it kinda stings the back
Anyways, I put some of that stuff on a paper towel and wiped it over the marker. It came off in one pass! So my first thought is "Damn this is strong stuff!". Of course, my next thought is "Exactly how strong is this stuff." This is the story of exactly how strong this Goof Off really is...
tommy
Re: HOT DAMN!!! This stuff works!!!
« Reply #1 on: May 26, 2005, 12:26:57 am »
Thats what most of us use to clean the paint off to get to original side art on a converted cab, no surprise there.
AlanS17
    • AlanS17
« Reply #2 on: May 26, 2005, 12:29:28 am »
It cut through marker like wiping up a spill so I pitted it against my toughest challenge. I pitted it against Dig Dug (or what I thought was Dig Dug).
Now Dig Dug is a tough opponent. He's got formica glue and 2 layers of paint covering his sideart. However, Goof Off was no slacker! Here are the results...
He turned out to be a Kangaroo is disguise with perfect (as far as I can tell so far) sideart!
paigeoliver
  • Awesome face!
« Reply #3 on: May 26, 2005, 12:31:30 am »
I did permanent damage to the overlay on my Drop Zone 4 when I set a bottle of cleaning fluid on it (which had goof off on the bottom), it ate a circular section of painted artwork, and at the black anodizing completley off, now the thing has a circle of shiny brushed aluminum on an otherwise black panel.
AlanS17
    • AlanS17
« Reply #4 on: May 26, 2005, 12:33:32 am »
The next test was to see how delicate it could be. So I put it up against my personal favorite - Ms Pacman.
It didn't remove the black like so many people complain about.
The picture is crappy because it was taken on a camera phone.
AlanS17
    • AlanS17
« Reply #5 on: May 26, 2005, 12:36:50 am »
Let me have my moment! This is a first for me...  :P
tommy
« Reply #6 on: May 26, 2005, 12:38:16 am »
The first time i tried to remove paint on a cab i used a harsh paint remover, and needless to say it removed everything.
AlanS17
    • AlanS17
« Reply #7 on: May 26, 2005, 12:38:53 am »
AlanS17
    • AlanS17
« Reply #8 on: May 26, 2005, 12:40:07 am »
It ate through the anodizing? That sucks...
paigeoliver
  • Awesome face!
« Reply #9 on: May 26, 2005, 01:22:01 am »
Yep, although it was sitting there for like 2 days.
NiN^_^NiN
« Reply #10 on: May 26, 2005, 03:24:26 am »
can you waterdown the goo off stuff for more delicate stuff?
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #11 on: May 26, 2005, 04:13:08 am »
Does anyone know a similar product that works well for glue? I have some glue stock to a sheet of glass that refuses to come off
crashwg
« Reply #12 on: May 26, 2005, 05:01:06 am »
What kind of glue is it?  You can get pretty much anything off glass with a razer blade.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
vibez
« Reply #13 on: May 26, 2005, 05:17:43 am »
Its actually a little alphanumeric LCD screen. I'm not sure what glue it is. I cant use a razor blade because the glue is not on the glass. the glue is actually on the back of some polorizing film which is stuck on the glass. I need to remove the glue without damaging the polorizing film. So really I need something that will dissolve the glue
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #14 on: May 26, 2005, 08:57:12 am »
Hmm... I've been searching for a few days for a local place that has 3M Safest Stripper, which I remember everyone here raving about for taking paint off a cab and saving the sideart.....
Maybe I should give this stuff a try also/instead.
first off your and idiot
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #15 on: May 26, 2005, 09:47:55 am »
Goo Gone is good for adhesives... Just let it soak. The adhesive turns to slime.
NO MORE!!
AlanS17
    • AlanS17
« Reply #16 on: May 26, 2005, 10:05:28 am »
This Goof Off worked well for glue, too. I don't know what it'll do to whatever it's stuck to, though.
19rjs99
  • Last login:January 30, 2019, 08:31:31 pm
« Reply #17 on: May 26, 2005, 10:07:24 am »
I second this... This stuff is great.
vibez
« Reply #18 on: May 26, 2005, 10:09:31 am »
Thanks. I'll try to find a uk supplier of goo gone
AlanS17
    • AlanS17
« Reply #19 on: May 26, 2005, 10:12:30 am »
Well my mom used to use Goo Gone to get gum out of my hair when I was little so I hope it's safe.
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #20 on: May 26, 2005, 11:17:03 am »
Goof off has a water based version that I use in the house.  Outside of the house I use the "will eat through concrete version"!
-d
Nothing witty here...move along.
AlanS17
    • AlanS17
« Reply #21 on: May 26, 2005, 11:43:42 am »
The one I've been using is "industrial strength" or something. Hasn't hurt the vinyl at all, though.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #22 on: May 26, 2005, 12:17:34 pm »
Is Goo Gone harmful to acrylics or plastics? I have to remove about 1000 square feet of Texas state "VOID foil" from a plastic Marquee. It is the front side so the paint is safe, but I'm worried about fogging the acrylic.
PS: Whoever thought it would be a good idea to put 16 Texas tax stickers on my marquee must certainly be burning in some sort of arcade He!! at this very moment >:(
AlanS17
    • AlanS17
« Reply #23 on: May 26, 2005, 12:21:23 pm »
LOL well I have no idea what it'll do to acrylic. Check that Goof Off, tohugh. It tells you right on the bottle what it will and won't eat through. I think it hurts some plastics but not others.
ethous
  • Last login:March 31, 2015, 04:38:35 am
  • Life is prescious enjoy every minute
« Reply #24 on: May 26, 2005, 12:22:52 pm »
Hmmm I wonder if i should try it on my galaga.
I was told could be to strong for it tho been there for a long time.
cw
  • Last login:April 23, 2024, 08:42:20 pm
  • Game over man game over
    • The Cab
« Reply #25 on: May 26, 2005, 12:58:05 pm »
After you finish getting the better part of the paint off or just just cleaning up scuff marks try  using the Magic Eraser  that Mr. Clean makes.....   Works wonders for cleaning cps too.... gets all the dirt and nasty stuff out of the pits and what not...
gcbrowni
  • Last login:January 02, 2020, 12:00:51 pm
  • Hear my Tale of Woe!
« Reply #26 on: May 26, 2005, 01:20:25 pm »
I agree with regard to the magic erasers. They remove an amazing of 'bad stuff', things I would have never thought possible.
RayB
  • There's my post
    • RayB.com
« Reply #27 on: May 26, 2005, 01:43:54 pm »
I'd like to make a point to everyone that Goof Off is strong (see Alan's post regarding burning nose hairs!)... whereas Goo Gone is very mild and even safe on your skin. It smells like oranges and is probably made from orange peels. Goo Gone is NOT a paint remover. It won't harm plastics, but they say not to use it on silk, leather, suede or rubber.
NO MORE!!
pointdablame
« Reply #28 on: May 26, 2005, 01:47:45 pm »
With how strong this Goof Off seems to be, why is it that it will take off paint/laminate glue and not harm hidden sideart?  Should it only be used if there is vinyl sideart underneath?
I guess I'll have to read up a bit more to see what might bring back my Mortal Kombat sideart. :)
nostrebor
  • SHOCKING!!
« Reply #29 on: May 26, 2005, 02:12:53 pm »
Thank you for the answer...
AlanS17
    • AlanS17
« Reply #30 on: May 26, 2005, 02:15:19 pm »
pointdablame
« Reply #31 on: May 26, 2005, 02:17:46 pm »
Right. It removes the glue and paint, but not vinyl sideart. However, that's operating under the assumption that the sideart underneath is in good condition. If the sideart is already worn, the Goof Off might affect it too.
Thanks.  Seeing as its covered it horribly spraypainted black paint, who knows what the sideart looks like... but there's only one way to find out :)
AlanS17
    • AlanS17
« Reply #32 on: May 26, 2005, 02:20:41 pm »
Here's a tip for yall trying to take paint off of vinyl sideart.
I figured this out last night. If you use a new plastic scraper rather than rubbing the paint off, you stand a better chance of preserving the sideart underneath. Rubbing grinds that Goof Off into the surface of the vinyl and pulls the color right out of it.
Be careful with the scraper too, though. You don't want to mark the surface of your side art by scraping too hard. Let the Goof Off do the work.
Don't be stingy with the Goof Off in spots that still have paint. Be cautious in the areas where the paint has already been removed. The trick is to get all the paint off the first time. That means using enough Goof Off. If you have to sit there and work it, the sideart has a better chance of coming up.
Hope this helps!!
nostrebor
  • SHOCKING!!
« Reply #33 on: May 26, 2005, 07:50:37 pm »
Goo Gone is acrylic safe!
Here is my cleaned up marquee after removing 7 Texas tax stickers. The stickers would leave a foil with the word void over and over and they covered at least 75% of the marquee face.
I put the marquee face down in a puddle of Goo Gone in a makeshift tin-foil pan while I ate dinner. It took a bit of scraping with a plastic scraper, but it did absolutely no damage to the plastic marquee.
It came out great!
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #34 on: May 26, 2005, 11:05:36 pm »
Lighter fluid (not butane).  I've yet to see anything sticky that it couldn't take off.  Evaportates with no residue too.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
empire2k
  • Last login:June 14, 2005, 01:47:19 am
« Reply #35 on: May 27, 2005, 11:26:46 am »
I didn't have a problem with rubbing the Goof Off to remove black paint from my Star Wars cab restoration. The original art looked fine afterwards.
I definitely agree with this. I had wiped a thin coat of Goof Off over about 1 sq. ft. of my cabinet to kind of pre-treat it, and then didn't get that section finished when I knocked off for the night. The next day I found that section noticeably harder to get the paint off of. I now make sure I only apply the Goof Off to sections I'm sure I'll be able to finish immediately.
