Author Topic: How I do remove permanent marker from formica?  (Read 5783 times)
AlanS17
    • AlanS17
« on: May 25, 2005, 07:05:11 pm »
When I bought a few of the machines I have, the previous owner (in his infinite wisdom) decided to mark which ones weren't working by writing "BAD" right on the side of the busted machines using a permanent marker.
Anybody know how to get that stuff off? I've got no idea how long it's been on there, but I'd venture to guess at least a couple of years.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: How I do remove permanent marker from formica?
« Reply #1 on: May 25, 2005, 07:13:58 pm »
Ugh.
You might try one of those "magic sponges" ... I have had better luck with those that anything else, including heavy-duty Goof-Off.
My 2 Year-Old got hold of a Sharpie and decided to colour on Daddy's brand-spanking-new notebook. It hadn't been sitting there for years, but the magic sponge cleared it up beautifully.
Failing that, I have (long ago now) soaked such stuff with Goof Off with reasonable results.
Good luck & Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
JODY
  • Last login:January 19, 2024, 05:06:29 pm
  • After a long delay...the arcade is underway!
« Reply #2 on: May 25, 2005, 07:17:45 pm »
I second his responses.
AlanS17
    • AlanS17
« Reply #3 on: May 25, 2005, 07:19:24 pm »
magic sponge... goof-off... I'll give 'em a shot. Thanks.
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #4 on: May 25, 2005, 07:20:42 pm »
Rubbing alcohol usually works pretty good on Markers too. Try it if you got it.
Bar that, I also recommend Goof-Off. Super strong stuff. I've used it to remove silk-screened art from some plastic cabinets. Just be careful with it & don't inhale the fumes for too long... You'll go loopy. (At least that's my excuse)
I'm not a freak!...
Oh wait...
Yes I am...
scooter
  • Last login:September 13, 2006, 09:57:01 pm
  • I want to build my own llama!
« Reply #5 on: May 25, 2005, 09:54:50 pm »
Use the stuff that cleans dry-erase whiteboards.  I accidentally (don't ask) marked up a desptop with a permanent marker. This stuff took it right off.
Friends don't let friends buy iROMs.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: May 26, 2005, 12:33:01 am »
If the stuff is actually on the formica, you can use lacquer thinner directly on it. You can also use rubbing alcohol (99% is prefered).
AlanS17
    • AlanS17
« Reply #7 on: May 26, 2005, 12:35:45 am »
I used the Goof Off. It worked wonders.
