Author Topic: Coin mech mounting suggestions?  (Read 1172 times)
D5A1AC
« on: May 17, 2005, 09:57:56 am »
Hi everyone, I'm building a cocktail cabinet ( www.mikesarcade.tk ) And I have a control panel which is the full width of the cabinet. I was thinking that I might mount a coin mech on the left "wall" of the cabinet, towards the top and closest to the front of the cabinet. Has anyone done this before? If so, how did it work out? I'd imagine that it wouldnt be too bad for one player games, as the player would just have to lean around the control panel a bit and put a coin in but for two player games, player one would have to insert a coin for player two every time s/he needed a credit (I cant afford to get a coin mech on each side, and two coin mechs is a bit dodgy).
Basically, what do you think of this idea?
Thanks a lot for your opinion  ;)
SirPeale
  • Green Mountain Man
Re: Coin mech mounting suggestions?
« Reply #1 on: May 17, 2005, 10:13:36 am »
You mean like a one-slot coin panel?  Like this?
http://www.pealefamily.net/tech/newmame/coindoor/
D5A1AC
« Reply #2 on: May 17, 2005, 10:22:23 am »
Sorry, yeah the one I was referring to is actually this one http://ozstick.com.au/prod_coinmechs.html its "cm01"
I think I'd set it up so all players get a credit when a coin is inserted
D5A1AC
« Reply #3 on: May 18, 2005, 03:48:41 am »
anyone there?  :-\
paigeoliver
  • Awesome face!
« Reply #4 on: May 18, 2005, 04:57:19 am »
anyone there?  :-\
What exactly do you need to know? You cut a hole in the side of the cabinet and put it in the hole.
D5A1AC
« Reply #5 on: May 18, 2005, 05:02:20 am »
I know that ;) But ive never seen a coctail cab with the coin slot on the side, only the front. What I would like to know is would this be practical, or annoying? I was hoping someone else had done it too so I could get thier opinion on a site mounted coin slot.
paigeoliver
  • Awesome face!
« Reply #6 on: May 18, 2005, 05:12:09 am »
Only the midway cocktails have them in the front, almost all other styles have them on the side (the player 1 side).
D5A1AC
« Reply #7 on: May 18, 2005, 05:19:04 am »
Really? Cool. I suppose it must be functional / practical and such to have the coin mech on the side then  :D  I dont know why I havent seen the coin mech on the side of any cocktail cabs before...
Thanks paigeoliver, Ill go with the side mounting then  :)
paigeoliver
  • Awesome face!
« Reply #8 on: May 18, 2005, 05:22:15 am »
Probably because you have only been looking at examples here, everyone here copies the Midway cocktail.
rockhopper
  • Last login:December 26, 2015, 05:15:36 pm
  • I love orange soda!
« Reply #9 on: May 18, 2005, 07:49:52 pm »
Hey D5A1AC,
Another Aussie?
http://forum.arcadecontrols.com/index.php/topic,27169.msg225629.html#msg225629
Here is my midway cocktail, with similar coin mechs on the side. Not sure if this is exactly what
you're after, but I have two coin mechs one on each side, and don't find anything dodgy about it.
All you need to do is make sure the back of the mech clears the monitor. You might also want to make it easy to
get the coins out, mines a bit difficult, as you have to pull the monitor out, but that means I don't empty out the coin boxes very often.
D5A1AC
« Reply #10 on: May 19, 2005, 07:05:13 am »
Yup, another Aussie. Actually I mean on the other side (i.e. the side facing more towards the camera on the first pic of yours), but I might mount it down really low like you have on the front of my cab, its just that the control panel is the full width of the cabinet and it might be a bit "fiddly" to insert a coin that way. I think I'll install the control panel first and just see where it is easiest to use before I mount it.
Nice cab btw  :)  Very professional looking, I'm going to have to get those stools from bunnings.
