Author Topic: 2 computer parts piles, what to do...  (Read 1080 times)
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« on: May 14, 2005, 10:41:47 am »
Comp pile #1: Dell Dimension XPS B800 (800 mhz P3, but no HD and no RDRAM sticks insode...)
Comp pile #2: Dell Poweredge 1400 (Dual processor P3 800 mhz, missing 1 processor. Looks like it takes standard ram...)
I have extra RAM (But no rambus) and HD's laying around. I have my Built by ati vid card. Do I go buy RDRAM, or use a SERVER computer for RAM?
Can you use a server with just one processor?
I have already tried to get in touch w/ Dell tech support, but since both of these machines are out of warranty, I can't get past the "Touchtone computer Nazi" phone system to ask them the exact specs of the RAM I need, if ECC or non ecc ram is reqd for a server, etc.
Suggestions?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: 2 computer parts piles, what to do...
« Reply #1 on: May 14, 2005, 10:49:12 am »
I have a 2450 that I pulled from my production rack yesterday. I have run it with a single proc and dual procs.
You may have to adjust the BIOS and/or put in a terminator card (2450 uses slot procs and you need to have a terminator card for the empty slot).
You may also have OS issues, depending on what OS you choose (Win98 may not like multi proc machines)
Cheers.
« Last Edit: May 14, 2005, 11:01:41 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
Mugzilla
« Reply #2 on: May 14, 2005, 11:11:23 am »
Is the "daughterboard" the little board that stands vertically by the processor? In that case, I only have one daughterboard..."
Where can I host a frigging picture w/o logging in?!?!?!? Tinypic is down...
« Last Edit: May 14, 2005, 11:13:30 am by Mugzilla »
CheffoJeffo
« Reply #3 on: May 14, 2005, 11:15:04 am »
I miswrote in my original post ... my 2450 had slot processors, not daughterboards.
If your processors are mounted on daughterboards, then you may need a terminator card. Or you may not, YMMV.
You might just power it up and see if it throws an error. If the BIOS doesn't mind things, hopefully the OS wouldn't either.
Sorry ... I'd like to be more help, but I don't have a 1400 (and the rackmounts are rather different than the boxes).
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
Mugzilla
« Reply #4 on: May 14, 2005, 11:17:44 am »
I'm going to try to fire this puppy up. It is sort of overkill, since it was built for some super-RAID setup.
We'll see what it craps back as me when I fire it up!
Dire Radiant
  • Last login:March 25, 2011, 03:11:36 am
  • Cor, chief!
« Reply #5 on: May 14, 2005, 12:03:45 pm »
Windows 98 will run on an SMP machine, it just won't take advantage of it.
I say throw some cheapy stuff in whatever is left over, add a halfway decent sound card and build a jukebox.
greven grevs
  • Last login:January 17, 2006, 03:24:19 pm
  • U.S. Air Force
    • The Greven Group
« Reply #6 on: May 14, 2005, 01:07:51 pm »
send it to me  ;D
