Main > Main Forum
All in one Console Game system
Pages: << < (2/5) > >>
Hoagie_one:
I've comtemplated using a cartrige, permantly attached to the console and actually storing the laptop harddrive in it.  Ihave to take the measurements first to see if it would work.  I only planned on hacking up the back of the case and maybe a slit on teh side for a cd-rom if I can squeeze it in.  Most likely use wifi adn stream everything.
Dunno.  I'm just at the measuring stages.  Might wait for the new micro-itx.  they are supposed to be only 12cm x 12cm
Flinkly:
ah...i was just planing to hack the outputs to the appropriate output plug on the back of the case.  even though this might mean reduced video quality, at least it's reaslistic of the era.  i'm trying to build my nes to look exactly like a nes on the outside.  my main worries are heat and space.  also, wifi is a good idea...i'll have to look into that.
what processor/board are you thinking of useing?  for old school games like nes and snes, i'm sure a via could handle the load.
Hoagie_one:
1 gig processesor most likely
AlanS17:
--- Quote from: Hoagie_one on May 11, 2005, 02:09:14 pm ---1 gig processesor most likely
Even the most basic VIA mini-itx board should handle NES and SNES emulation just fine.
Hoagie_one:
im also gonna use it to stream media to the livingroom stereo
Go to full version
