Author Topic: Hooking up a TV to your computer  (Read 1357 times)
2PacMan
  • Last login:November 06, 2009, 08:33:45 am
  • PacMan collection
« on: May 11, 2005, 10:50:15 am »
Is there a tutuorial somewhere that explains exactly how to hook up and use a TV for your computer monitor?  At first i was going to use a computer monitor for MAME, now i want to use a TV instead.
Stingray
Re: Hooking up a TV to your computer
« Reply #1 on: May 11, 2005, 11:08:13 am »
Get a video card with S-Video or composite out.
-S
2PacMan
  • PacMan collection
« Reply #2 on: May 11, 2005, 11:18:16 am »
And that's all i need and i'll be set?  No special software or wiring?  Do alot of people use TVs for MAME?  Is the resolution OK??  I know probably arcade monitors would be the best, but is a TV ok as well.  I need about a 19'' screen, and i don't want to pay a ton of money for a 19'' monitor, plus it's too big for my cab, it sticks out the back.
ahofle
    • Arcade Ambience Project
« Reply #3 on: May 11, 2005, 11:33:37 am »
Yep, just make sure your TV has an S-Video input.  Some of the cheaper ones only have composite.  I have a 24" TV in my cab and I am very happy with it.
maxxonline
  • Last login:June 17, 2005, 09:28:42 am
« Reply #4 on: May 11, 2005, 11:44:22 am »
Yeah I plan to go this direction as well with a 27" TV in my cab.
unclet
« Reply #5 on: May 11, 2005, 12:22:51 pm »
Love my 27" TV in my cabinet.   Arcade games are not suppose to be crystal lcear anyway, so in my opinion (if you not getting an actual arcade monitor), then a TV is better than computer monitor.  Plus you can still watch TV on it as well..... just connect your cable from your wall to it and your ready
ahofle
« Reply #6 on: May 11, 2005, 12:29:54 pm »
Another benefit of a TV is the emulation or direct connection of consoles (which were made to run on TVs).
markrvp
  • NFL Expert
« Reply #7 on: May 11, 2005, 12:32:47 pm »
For my computer at home I just put in a Radeon 9200SE from CompUSA.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #8 on: May 11, 2005, 01:09:09 pm »
I've read that Radeons tend to have better TV-OUT than GeForces. Any experienced opinions in that regard?
I have personally witnessed S-Video out from my Radeon 9800PRO256, and it looked great.
I have also heard that some Midway games (MK, Rampage, etc) can cut off part of the image when viewed on a TV. I am not sure about that one.
KenToad
  • Last login:May 05, 2024, 08:22:38 am
  • Flap Flap Flap
« Reply #9 on: May 11, 2005, 01:57:26 pm »
-S
What if you have onboard video .... i.e. no video card slot and therefore only a standard monitor out?  Are there any decent adaptors to convert from a standard monitor port to TV?
Thanks in Advance,
KenToad
Hoagie_one
  • Um....whats a cabinet
« Reply #10 on: May 11, 2005, 02:23:51 pm »
KenToad
  • Flap Flap Flap
« Reply #11 on: May 11, 2005, 02:40:40 pm »
Whoa, thanks Hoagie.  I guess it probably would have been smarter just to do the search myself.  Sometimes I get lazy like that.
*Edit* Any thoughts on quality differences, or do all those products function pretty much the same?  And are they different/worse than an S-video adaptor to A/V cables.  I already have an S-video convertor for the labtop--not good for fine print, but fine for gaming and watching decent quality vids.
Cheers,
KenToad
« Last Edit: May 11, 2005, 02:43:41 pm by KenToad »
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« Reply #12 on: May 11, 2005, 06:59:26 pm »
I have a Radeon9250 PCI only.  I hooked it up to a 19" TV using a S-video to composite converter and was not happy with the results.  The window was angled off by like 2-4 degrees.  The software itself supports rotating the image but only in increments of 90.   I could compress the image, but then it looked too small for vertical games.
With that, fuzzy text, and the immense weight of the machine using a 24-27" TV, I decided to go with the PC monitor.  At least I can play Half-Life in full glory standing up( I sit down all day in my day job ).
NJDevils2006
  • Last login:September 14, 2006, 08:20:32 pm
  • proof the Mark Messier likes boys!
« Reply #13 on: May 11, 2005, 08:27:21 pm »
You can use a KeyDigital VGA to Component Video adapter if your TV will accept such a connection.  I use my PC on a 57 inch Hitachi TV and it looks pretty good.
I work in the Audio/Video field, and have found that KeyDigital converters seem to work out the best (IMO).  We use them everyday.
At least the fans go to hockey games "for the love of the game"........to bad the players don't!
