Main > Everything Else
Hallelujah!!
HaRuMaN:
Also made a pulley. This was neat, as we did everything from start to finish. Made a sand mold to cast the blanks, and then turned it on a lathe. Broached a keyway through the center hole, also drilled and tapped a hole for a set screw. I had fun with this one until I broke the carbide cutting tool on the lathe... :-X
ClubNinja:
Nice fingernails ;)
HaRuMaN:
--- Quote from: ClubNinja on May 13, 2005, 11:04:21 pm ---Nice fingernails ;)
Why thank you... I guess... lol. 8)
Franco:
--- Quote from: HarumaN on May 12, 2005, 06:52:53 am ---Also made a pulley. This was neat, as we did everything from start to finish. Made a sand mold to cast the blanks, and then turned it on a lathe. Broached a keyway through the center hole, also drilled and tapped a hole for a set screw. I had fun with this one until I broke the carbide cutting tool on the lathe... :-X
How did u manage to break the turning tool? I assume you just broke the insert? What happened? Just interested as im a CNC turner.
HaRuMaN:
--- Quote from: Franco on May 14, 2005, 06:52:35 am ---How did u manage to break the turning tool? I assume you just broke the insert? What happened? Just interested as im a CNC turner.
Well, this wasn't a CNC lathe, it was manual, with power feed, etc... I had the pulley butted up against the chuck, and was turning the outside diameter with a slow feed rate (finishing pass) and I let the tool go just a hair too far, and it hit the chuck, and the chuck broke the carbide tip right off... :-[ I was so embarrassed, lol. Luckily, the instructors were cool about it, and just gave me another tip. :D
