Main > Main Forum
Formica or another material?
Pages: << < (5/6) > >>
BUCKETHEAD:
That was the idea.
So i would have some play with it.
Trust me it ain't coming back off.   ;)
dema:
--- Quote from: BUCKETHEAD on May 11, 2005, 08:14:50 pm ---That was the idea.
Wade:
I have pre-cut formica to the correct size before.  I lay a straight board under it (like a very straight 2x4), then clamp the formica to it, then run the router down the board with a flush trim bit (just like you would use to trim the edge off in a normal formica installation).  That is how I get a straight cut with the formica not glued yet.
Then, I apply the contact cement to both surfaces, and let it dry.  Don't worry about the positioning!!  Just stick a few dowels up under it so you can space it out, then slide the dowels out one at a time.  It is no big deal.  You don't even have to use dowels, you can use some thin scrap wood strips, some stiff wire, etc.
It is important to let it dry fully, I have put it on before without it drying enough and it didn't stick nearly as well.  And, sometimes it is necessary to put two coats of the cement.  I also found the oil based formica glue to be slightly better than the water based glue.
Also, it helps a lot to rough up the old material first, especially if it was laminated to begin with.  I usually hit it with a sander and some heavy paper, like 60 or 80 grit.
Wade
RayB:
What are dowels?
dema:
--- Quote from: RayB on May 12, 2005, 11:12:36 am ---What are dowels?
Dowels are just strips of wood
Go to full version
