Author Topic: Wiring up Joystick???  (Read 1726 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: May 09, 2005, 09:24:36 am »
Iv wired up my happs joysticks no problem but iv recently bought som e sanwa ones and not sure how to do this as i cant even see the cherry switches or the bits you connect the wires to.
Can anyone help??
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Wiring up Joystick???
« Reply #1 on: May 09, 2005, 09:36:52 am »
I've never wired one, but I believe you use the 5 pins that protrude from the side. They should be something like:
- Common (ground)
- Up
- Down
- Left
- Right
Edit: Here's a standard wiring harness.
« Last Edit: May 09, 2005, 09:46:43 am by JoyMonkey »
dave 1945
  • Last login:June 24, 2005, 02:00:50 am
  • A What!
    • The Snail
« Reply #2 on: May 09, 2005, 09:47:07 am »
5 pin joystick cable
http://www.himuragames.com/store_joyacc.php
is what you need i dont know what each wire does maybe someone round here knows that.
Marky_1979
    • Personal Webspace
« Reply #3 on: May 09, 2005, 09:52:58 am »
Yes thanks guys i had seem that wire but wasnt to sure if it could be used for emulation projects. I f anyone knows what each wire does would apreciate that alot.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: May 09, 2005, 09:59:18 am »
The first pin is probably ground. Then the others are directions. You can just hook em up and try out the directions to see which you've mixed up.
NO MORE!!
MinerAl
  • Last login:March 21, 2023, 07:11:28 am
  • duck
« Reply #5 on: May 09, 2005, 10:11:07 am »
It depends on which way you turn the stick...
I would guess black is ground.  Plug in your stick, make sure it is oriented the way it will be in the CP and plug black and one other color into your encoder (or to a multimeter) and see in which direction it closes the circuit.   Write it down, and make sure you don't turn the stick 90,180, or 270 degrees when you put it in your CP.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #6 on: May 09, 2005, 12:25:23 pm »
The microswitches are there.  They are under neath the clear plastic restrictor plate.  The restrictor plate snaps on and off so you can take it off to see the switches better.  You should be able to solder to the tabs on the switches like normal except you only need to wire a ground to one of them since the PCB conects all the grounds for you.  If don't want to solder and you don't have one of those 5 pin conectors the pins on the pcb are spaced the same as the ones for a standard hard drive or floppy drive cable.
mr. tweedle
  • Last login:July 04, 2005, 09:49:00 am
  • Blondes make the best victims
« Reply #7 on: May 09, 2005, 01:57:26 pm »
With the pins facing towards you starting from left:
ground
down
up
right
left
